SL/R230: rear compartment center console
Old May 10, 2018 | 09:12 AM
wardhill's Avatar
2003 sl500
is there a way to open theses ? key wont over ride in glove box, fuse 71 is good central locking system is workin fine
2003 sl 500
Old May 10, 2018 | 11:42 AM
White Spyder's Avatar
2003 R230
a photo of what you are trying to open would help.
Old May 10, 2018 | 12:09 PM
wardhill's Avatar
2003 sl500
sorry for no photo but they are the two compartment behind seats one holds the cd player. center console is just that.
thanks for responding
Old May 10, 2018 | 04:26 PM
Aussiesuede's Avatar
SL500
Those cubbies are locked via the central locking system and if there is a leak in the air line to either of them, then they'll remain locked. Many times when such a lek occurs, owners decide that it isn't worth it to them to pay the amount the Stealership wnts to charge to repair the leak, so they just allow them to remain locked since the storage capacity is pretty minimal and most don't use their CD players anymore. There are two panels in front of the cubbies that are imply compression mounted, no screws to remove. If you wedge a screwdriver or butter knife behind the panel, they''ll simply pop off and provide access to the latch catch. I've seen the latch catches secured by either two small bolts or 2 rivets. If you don't want to goto he dealer for a proper repair of the system, you can gain access by either drilling out the rivets to the latch catch, but know that this would not allow you to secure the cubbie lids any longer. Those lids have a slight spring loading, so without the latch catch, they'll remain in the open position. To remedy this, you can glue a 1 lb weight to the front interior edge of each lid and that's sufficient to keep the lids in the down position. So that leaves you with the following choices:
1. Have the dealer repair the system. $$$
2. Accept not using the cubbies.
3. Proceed with the above understanding the caveats mentioned.
Old May 10, 2018 | 05:46 PM
2003 R230
"Center" threw me.
Old May 11, 2018 | 08:04 AM
wardhill's Avatar
2003 sl500
Its interesting that the center console remains locked too are they on the same air hose. When i noticed this problem the glove box was locked too but i could open that with a key i had never had the glove box lock itself i wondered if i did something inadvertantly with the key fob?
Old May 11, 2018 | 10:25 AM
moretech's Avatar
2003 sl 500
locked compartments
Only a wild guess but you might try locking and then unlocking the glove box using your key and see if everything works now. Good luck.
moretech
Old May 11, 2018 | 03:16 PM
SL500
Yes, the center console and rear cubbies share the same air circuit. If the rear cubbies are locked, then so too would be the center armrest console. Luckily, that lock can be easily defeated by simply placing a plug in the yellow tube leading to the center armrest control locking mechanism. This of course would mean your center armrest console would always remain unlocked, which considering less than 1% of all vehicles on the road have locking center armrests - most aren't bothered by such an eventuality. Accessing the air tube requires removing the center console wood trim so you can access the bolts holding down the center armrest so you can gain access to that yellow tube leading to the lock. Just make sure the armrest is unlocked when you plug the tube and it won't lock itself again when you use the central locking system. And for clarity, you unplug the tube from the locking mechanism and plug it so that the airline doesn't remain open and the rest of the central locking system remains unaffected.
This is a pretty common problem, and because of the $$$ charged by the dealership for tracing down just where the air leak has occured, many folks balk at spending $$$ having this issue fixed. Compounding issues is that a break in a wire leading to the locks can return a false value for the state of the lock and can return the same symptoms, so the dealer has to account for both possibilities when making an estimate for repair, and tracing wires and airlines means time dismantling to access said airlines and that means $$$'s.
Old May 12, 2018 | 11:13 AM
wardhill's Avatar
2003 sl500
Thanks this is good information
