SL/R230: Roof flap replacement
Old May 17, 2018 | 11:25 AM
AdoptedYorkie's Avatar
SL350
Afternoon everyone,
Sorry if this is a topic elsewhere, but somehow (I have no idea how), one of the hinged roof flaps that cover the brackets of the roof has disappeared in my SL 350.
Does anyone know if you can get the hinged cover as a spare part?
Photo attached of the space that has been left!
Thanks!
AY
Old May 17, 2018 | 12:29 PM
moretech's Avatar
2003 sl 500
small flap
Common headache, plastic shaft pins break and it flies off. You need to buy the whole assembly but there was a member who had 3D printed some. Other members may reply. When I first read about this in the forum I got out and secured mine with some elastic to bolts in the upper trunk area to be sure this did not happen. So far so good.
moretech
Old Aug 12, 2018 | 09:11 AM
sguelpen's Avatar
SL55AMG
I just found a guy on ebay who makes this part on a 3 D printer. I ordered it and will let you know once I receive it.
https://www.ebay.com/i/112619262405?...3D112619262405
Old Aug 15, 2018 | 01:50 PM
twilightround's Avatar
SL500
I got a replacement at a nearby salvage yard for less than the 3D printed version, and of course the vinyl cover matched. Very easy to take off the larger panel and insert the new flap.
Old Aug 16, 2018 | 02:19 AM
ozc204's Avatar
2003 SL500
You won the lottery man.
Old Aug 16, 2018 | 02:25 AM
ozc204's Avatar
2003 SL500
No affiliation
but this system rocks. I did both mine
https://www.ebay.com.au/itm/REPLACEM...IAAOSwImRYd5sg
Old Aug 16, 2018 | 02:27 AM
ozc204's Avatar
2003 SL500
Actually ...I am positive that I have that flap
Is it the LH definitely and in black
I found the flap in the door pocket after I used the replacement system I posted.
Old Aug 19, 2018 | 09:38 AM
sguelpen's Avatar
SL55AMG
Anybody got instructions on how to install this flap? Do you need to remove the entire panel?
Old Aug 19, 2018 | 01:06 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Yes, you need to remove the panel. It's fairly easy:
http://benzbits.com/r230/HingeTrimPanel.pdf
Old Aug 20, 2018 | 08:33 PM
cadbob's Avatar
2003 SL500, 2016 F250, 2017 Jeep Renegade
moretech
How did you secure it, I would like to do mine as well.
