Mercedes Benz R230 ABC parts and numbers public spreadsheet
Subscribe
May 19, 2018 | 01:52 PM
Started to work on a spreadsheet to list all parts (including IDs/numbers) of the ABC system. I'm using an online Google spreadsheet that is public and editable so that people may contribute to the information they can. Please feel free to edit it and share any information on parts you believe will be valuable to the community:
https://docs.google.com/spreadsheets...it?usp=sharing
Is very basic now but I see it as a long-term project.
Reply 0
May 19, 2018 | 03:22 PM
Does anhbody know the part number of the ABC hoses, this will be of great help!
Reply 0
May 19, 2018 | 04:07 PM
A 230 320 70 53 LINE FROM RADIATOR TO Y-PIECE WITH TEMPERATURE SENSOR
A 230 320 96 53 PRESSURE LINE FROM RADIATOR TO RESERVOIR
A 230 320 71 53 LINE FROM RADIATOR TO RESERVOIR
A 230 997 66 82 HOSE FROM VALVE BLOCK FRONT TO SUSPENSION STRUT FRONT RIGHT
A 230 320 03 54 LINE FROM VALVE BLOCK FRONT TO SUSPENSION STRUT FRONT RIGHT
A 230 997 67 82 HOSE FROM VALVE BLOCK FRONT TO SUSPENSION STRUT FRONT LEFT
A 230 320 04 54 LINE FROM VALVE BLOCK FRONT TO SUSPENSION STRUT FRONT LEFT
A 230 320 04 53 LINE FROM Y-DISTRIBUTOR TO VALVE BLOCK FRONT
A 230 320 00 72 LINE FROM PRESSURE RESERVOIR TO VALVE BLOCK FRONT
A 230 997 04 52 HOSE FROM T-PIECE TO RETURN ACCUMULATOR REAR (INLET)
A 230 320 02 54 LINE FROM T-PIECE TO RETURN ACCUMULATOR REAR (INLET)
A 230 997 05 52 HOSE FROM T-PIECE TO RETURN ACCUMULATOR REAR (RETURN)
A 230 320 68 53 LINE FROM T-PIECE TO RETURN ACCUMULATOR REAR (RETURN)
A 230 320 57 53 LINE FROM INLET OIL LINE TO VALVE BLOCK REAR
A 230 320 58 53 LINE FROM RETURN OIL LINE TO VALVE BLOCK REAR
A 230 320 67 53 LINE FROM RETURN OIL LINE TO VALVE BLOCK REAR
A 230 997 06 82 HOSE FROM VALVE BLOCK FRONT TO SEPARATION POINT ON MAIN FLOOR (INLET)
A 230 320 05 54 LINE FROM VALVE BLOCK FRONT TO SEPARATION POINT ON MAIN FLOOR (INLET)
A 230 997 07 82 HOSE FROM VALVE BLOCK FRONT TO SEPARATION POINT ON MAIN FLOOR (RETURN)
A 230 320 69 53 LINE FROM VALVE BLOCK FRONT TO SEPARATION POINT ON MAIN FLOOR (RETURN)
A 230 997 32 82 HOSE FROM PULSATION DAMPER TO T-PIECE (INLET)
A 230 997 33 82 HOSE FROM PULSATION DAMPER TO T-PIECE (RETURN)
A 230 320 41 53 LINE VALVE BLOCK
A 230 320 00 54 LINE FROM VALVE BLOCK REAR TO SUSPENSION STRUT REAR RIGHT Replaced by: A 230 320 12 54
A 230 320 12 54 LINE FROM VALVE BLOCK REAR TO SUSPENSION STRUT REAR RIGHT
A 230 320 01 54 LINE FROM VALVE BLOCK REAR TO SUSPENSION STRUT REAR LEFT
A 230 320 02 53 LINE FROM PRESSURE RESERVOIR TO VALVE BLOCK REAR Replaced by: A 230 320 16 54
A 230 320 16 54 OIL LINE FROM PRESSURE RESERVOIR TO VALVE BLOCK REAR
A 230 320 06 54 LINE FROM PRESSURE RESERVOIR TO VALVE BLOCK REAR
A 230 320 03 53 LINE FROM RETURN ACCUMULATOR TO VALVE BLOCK REAR
A 230 320 55 53 OIL LINE FROM REAR VALVE BLOCK TO CONNECTING HOSE LEFT REAR Replaced by: A 230 320 98 53
A 230 320 98 53 OIL LINE FROM REAR VALVE BLOCK TO CONNECTING HOSE LEFT REAR
A 230 320 07 54 LINE FROM REAR VALVE BLOCK TO CONNECTING HOSE LEFT REAR
A 230 320 56 53 LINE FROM REAR VALVE BLOCK TO CONNECTING HOSE RIGHT REAR Replaced by:
A 230 320 99 53 OIL LINE FROM REAR VALVE BLOCK TO CONNECTING HOSE RIGHT REAR
Reply 1
May 19, 2018 | 07:02 PM
Thank you Japp! They are listed now, will add pictures of each one of them for easy reference. If there are more parts with their respective part numbers of the ABC system you can share it will be very appreciated!
Reply 0
May 20, 2018 | 06:14 AM
There's loads more.
Tip: If you get the Mercedes EPC then all this info is easily accessible.
Reply 0
May 22, 2018 | 06:20 AM
How do I get the Mercedes EPC? I'mm guessing is not very simple to access it, thus the table I'm working on will benefit many.
Please do let me know, and if is not too much to ask it would be very appreciated if you can provide a full list of all the components and part numbers of the ABC. I will classify them, post each picture component, and do my best to create a good reference to fixing ABC issues.
Reply 0
May 22, 2018 | 10:29 PM
It's part of SDS. It also (usually) comes with WIS. You can get WIS for about $25 on eBay.
Reply 0
May 24, 2018 | 05:27 PM
found the software, still I believe an online resource for ABC issues and parts will help many.
Reply 0
Explore
May 24, 2018 | 08:42 PM
One of the challenges that there are many different versions of the same parts based on model year and engine.
Reply 0
May 26, 2018 | 04:56 PM
Quote: One of the challenges that there are many different versions of the same parts based on model year and engine.
Will add multiple tables and try to list each year of r230 and r231.
Reply 0
Aug 10, 2020 | 11:59 AM
hello i have a 2003 MB sl55 amg i am trying to figure out how to replace the hydraulic line pt# A230 997 06 82 if anyone can please help it looks like you would have to drop the sub frame or pick up motor
Reply 0
Aug 10, 2020 | 02:02 PM
Quote: hello i have a 2003 MB sl55 amg i am trying to figure out how to replace the hydraulic line pt# A230 997 06 82 if anyone can please help it looks like you would have to drop the sub frame or pick up motor
There's an easier way to do it - have a look at this thread .
Reply 0
Aug 10, 2020 | 02:26 PM
so i have already purchased the new hydraulic line thinking it wouldn't of been such a pain in the butt... would rather just replace the whole thing ya know?
Reply 0
Oct 29, 2025 | 04:59 PM
What about the line from the back of the pump.
What about the line that runs from the back of the power steering pump with a banjo fitting runs along the radiator bottom curves around goes back along the driver side of the transmission to the back of the car.
Reply 0
Nov 4, 2025 | 04:06 PM
Find it here: nemigaparts.com
Reply 0
Subscribe
Currently Active Users (2)
