SL/R230: Hydropneumatic Spring Leg
2003 SL500
does anyone have the right part number for the front Hydropneumatic Spring Leg on the passenger side of this vehicle? they told me my air bag is blown up
MBworld Guru
I always pronounced "CLK as "Click". Regardless, this wouldn't be for a CLK, either, as they did not have "hydropneumatic" suspensions. They had only traditional gas-charged shock/strut suspensions. So, maybe an E-Class? Or a CLS?
2003 SL500
2003 SL500
I believe it is
2303202813
but please confirm
one mechanic told me it was AIR BAG suspensions??? does that make sense to anybody here?
is this something that only the dealership can do or can I hire a third party to do it as mercedes dealership in my city charges $149 /hr and they are probably looking at 2.5 hours
2303202813
but please confirm
2003 SL500
it was back in the day
MBworld Guru
The part number you posted is for the front right ABC strut. It has been superseded by part number A2303208813. I think your best bet is to buy an aftermarket Arnott strut and to find a new mechanic! The R230 SL never had and "airbag" suspension (known as Airmatic in BZ terms). The USA-model R230 came only with Active Body Control (ABC) which is a pressure pump driven hydraulic system.
2003 SL500
2003 SL500
Former Vendor of MBWorld
Contact Arnott with your V.I.N. and they will do a quick search to make sure you get the right part. ABC shocks are always in tight supply.
https://www.arnottindustries.com/contacts
MBworld Guru
Did you put it on diagnostics and check the readings from the sensors? I think if the internal strut travel sensors are bad, you get a dash warning message. But if the external ride-height sensor is just mis-reporting because it has failed, you may not.
2003 SL500
the other day I blew up a tire and it didn't know what the hell was going on
it only messages me when I am out of gas or running out of engine oil
2003 SL500
