SL/R230: Paint Brake Calipers or not? Red?
I have a black 2008 SL550 with the AMG Sport Package. My brake calipers are starting to look pretty bad (mainly the bolts are rusting, ). I know I could upgrade to some bigger 6 piston calipers (or even better upgrade to an SL55 or SL65...) but honestly I am happy with what I have and just want to improve cosmetically. I have looked at different options, and I'm thinking about simply painting my calipers. Below is what my wheels and calipers look like now (sorry the spokes are right in the middle of the caliper, but you can see the rusty bolts):
After reading other posts, I think I will go with the G2 epoxy paint (brush on), but I'm looking for any advice, suggestions, or personal experience (are there any drawbacks to the epoxy paint).
Also, I have seen this caliper with a "Mercedes Benz" logo and with an "AMG" logo (although I'm not really sure this is a true AMG caliper, although I do believe it is made by Brembo)? My calipers don't have any logo showing.
So, should I paint the calipers or not?
G2 epoxy paint or something else?
Red, silver, or black?
Logo: AMG, Mercedes Benz, or no logo?
Any advice, suggestions, or pictures?
Lee
Black 2008 SL550 (AMG Sport package)
https://www.ebay.com/itm/5-X-4-Curve...PRQ:rk:23:pf:0
I may have to do the same when it comes time for brake fluid change.
If you make it red or black (or other bright color), calipers will hit the eye, which is not the case unless its something like 8-piston AMG calipers. And it will make you MB look like impreza
However, I thought I would do some mock ups in Photoshop just for fun (I didn't do the rear caliper, as it was hidden in this picture anyway).
I was really leaning towards black or silver, but after doing the mock up, I don't think the red is too bad (I think the silver or black will get lost and be transparent... maybe that is good thing?). See below:
Current
Current with rusty bolts...
Silver
Silver, not much different, except rusty bolts hidden.
Red
Red, not sure I have color exactly right, but I tried to make it slightly transparent to simulate if they were a little dirty.
Black
Black, this just makes the caliper disappear.
Any thoughts, comments, or personal experiences.
Lee
Bright colors attract attention to the detail itself. So the detail should be worth highlighting, like huge AMG brakes that cover almost 50% of the brake disc.
Otherwise it's like putting 20-inch wheels on a car with brake drums. So everyone can see that you spent all your budget for wheels
For this car silver highlights calipers, so they don't disappear, but at the same time it does not put it in the first place.
But if you want to put accent on the calipers red would be nice too.
Lee
Lee
I cleaned the calipers with brake cleaner and a wire brush. Masked some areas (I'm a horrible painter), and then started painting using the small paint brush that came with the kit. At first the paint didn't seem to cover all that well, but it looks much better once it dries and cures. I did my best to paint the back side of the caliper, but I'm sure I didn't cover the back side well at all. There was way more than enough paint in the kit. The instructions say to apply multiple coats, with 15 minutes between coats. However, I found that with the second coat (even after 15 minutes, and more), the paint on the caliper from the first coat was sticky and the brush tended to pull it and leave more brush strokes... After the second coat, I left it and it dried very nice and the color is even. You can certainly see some texture and roughness in the metal through the glossy paint, but from 1 meter they look great. I finished it with a black decal from ebay.
I think silver would have looked very nice as well, but with all the work, I thought red would be a nice subtle accent (I think silver would get lost behind the wheels). Overall, I'm happy and it certainly looks better than before (of course bigger brakes would look nice too!).
BEFORE AFTER
way better, personally prefer the OEM look so same color as it came with.
