SL/R230: is this oil or trans fluid dipstick tube ?
if this is engine oil, where is trans fluid dipstick? and vice versa.
thanks.
No way to check it without lifting the car while level, warming to 45 degrees C, then testing for over-flow from the fill tube. Also uses the new low-viscosity energy-saving blue fluid, not the old school red fluid.
Most 5 speed 722.6 transmissions have the dipstick tube, which is helpful.
I have both in my stable, and have been through the fluid change process for both.
Are you putting it in the correct tube? The taller one is oil, the shorter one is trans.
