SL/R230: new member question
new member question
I joined the forum today and posted a message to the R230 forum and it has disappeared. What's up with that? It was in the forum along with a small attachment and had a few views. I went to dimmer and when I came back t was gone.
Mike.
Mike.
MBworld Guru
Hi Mike, my guess is that the forum software "auto-moderated" your post. I think there may be a certain number of posts you must have before it will allow you to post links or photos.
Yes I must have posted too soon after joining, it seems fine now. I joined a couple of days ago and replied to an existing post but when I came back today the system didn't recognize me as a member so I joined again. Maybe that had something to do with it too.
At any rate it seems fine now. thanks.
Thanks for the welcome. I've lurked around here for years and only joined now because I am considering replacing the headlamp washer nozzles in the SL and there's a wealth of knowledge here. I was introduced to this site by my father in law who is a Mercedes enthusiast and car collector but just passed 90 years and is no longer active. I have both the SL and a C300 that have come from him. I've been turning wrenches since I got a mini bike when I was 11 years old and professionally in the 1970's. I still have old cars and a motorcycle that I have restored and maintain but haven't kept up with automotive technology. I left mechanics for computer programming and my auto mechanic skills are mostly stuck in the 70's. when ars had points and plugs.
The SL500 is a 2005 with 23k miles and in mint condition and the headlamp washer nozzles are the only problem right now. The job looks pretty straight forward and the only problem that I expect to have is handling the bumper cover alone when I remove and replace it. That is if I decide to do it myself.
Mike.
Mike.
2007 SL550 & 2012 S550 4matic
Welcome '''. Unless the nozzles are leaking and making a mess you could conceivably get along just fine never using them. Other forum members have commented on the volume of fluid dispensed as extreme overkill and destroys your clean car. Do you use the headlights washers on other MB? Plenty of opportunities to turn wrenches on your new SL as you can learn about in this forum.
ps I could not open attachment pictures.
The SL is not new to me, I've had it for years but it has been good to me with few repairs. I've done oil changes, engine and cabin air filters, changed batteries once and replaced the alarm siren recently. The car is mint and I'd like to keep it that way.
I'm not looking for excuses to turn wrenches, I have plenty of opportunity for that with five cars and a motorcycle here. I am considering having the dealer do the job becasue I am alone and the bumper is large but I'm leaning towards doing it myself.
Mike.
I do not have the MB DAS Xentry system, but other forum members do. Perhaps a member could look into providing you with the R and R instructions for the job, part numbers too. You will have a better idea of what is involved even if you elect dealership repair.
The nozzles are a little ball and socket assembly and the ***** have shot out like BB's. Now the water comes out onto the hood like a garden hose. The headlamp washer comes on automatically with the windshield washer periodically so I can't use the windshield washer until the headlamp washer is fixed.
Mike.
Mike.
Mike.
I hear ya but I'd like to keep the car as close to 100% as I can. It only has ~25k miles on it. I have a pro body man friend that will smooth and paint the scuffs on the bottom of the bumper cover while it is off of the car which gives me a little more incentive to do it. I've read through the procedure and removing the bumper cover looks pretty straight forward. I'm not decided yet but I'm leaning towards doing it.
Mike.
Mike.
Originally Posted by alk247
There are three features that are utterly useless in a 300 hp rear wheel drive $100k+ roadster - headlight washers, windshield wipers heater and windshield fluid heater. All designed for cars driven in snow, ice and cold.
2. I believe that you are rather an exception, than a rule. Mot people here do not drive their SL in the snow. I, personally, try not to drive it even on a wet surface, if I can. I also do not use SL for ski trips (not that there is a convenient way to haul skis in it).
So I replaced the headlamp washer nozzles and just tested them and they make a mess of the hood even when they are working correctly. It sprays far and wide. I may pull the fuse on them after all but I don't regret repairing them It is my opinion that this is a 14 year old car that came to me in near #1 condition and I'm going to keep it that way. I'm having the curb scuffs on the bottom of the bumper painted while it is off the car which will be nice too.
Does anyone know if the headlamp washer has a separate fuse?
Mike.
Mike.
OK so I found the fuse chart in the tool kit in the trunk of the car. It tells me that F38 is the fuse for the headlamp washer. I located and removed 7.5amp fuse f38 and the headlamp washers still work.
Any help?
Mike.
Any help?
Mike.
