SL/R230: ABC accumulators
The system was systematically serviced.
Struts were replaced as well as some hoses, valve body and the ABC pump.
There were few instances where the brief ABC warning would show on the dash while going over bigger bumps. Neither MBII scanner nor the Star system detected any faults. System flush made no difference, at least to the issue at hand.
From reading about it around here I notice lot of similar problems related to the ABC return accumulators. They were never changed so I decided to give it a try.
Ordered a set and replaced both, front and back. It is a straight forward procedure that been covered here in several treads. Providing you get the MB hydraulic line disconnect tool ($20) you can be done in no time.
There was very little loss of the fluid since the car was lifted of the ground completely. After initial inspection the old accumulators look good to the naked eye. Basically no different than the new one. Membrane still sitting high and looking to be in good condition.
Well, the worst case scenario here would be me wasting 125 bucks on parts not needed. But wait just a minute here, during the removal and installation process I notice a significant difference in the weight of the parts. After putting the old and the new on the scale one can clearly see, there is almost a pound in difference. I think you all know where I’m going with this. Membrane was leaking and they were full of fluid.
Needless to say the ABC warning never came back again.
http://mercedes-abc-drive-carefully....y-part-of.html
Mike.
Mike.
Happy wrenching 😉
If you conclude there is a problem, then two back-to-back Rodeo routines may correct it. A Rodeo followed by a fluid flush would be even more effective. Rebuilding the valve block is a last resort. And doing nothing at all is an option too.
I posted that link as an FYI to the group.
Mike.
It concerns me a little that there is a chance that changing the filter without a flush can dislodge some contaminant doing more harm than good. What do you guys think about that?
Mike.
EDIT - I said above that the ABC doesn't have a problem but it dies sag on one corner when parked. I'll test to see how long it takes to sag the next time I park it for long enough to see it happen. I just can't say from memory.
You don't need to fully remove that rear assembly to change accumulator but I still want the $20 tool. I usually see it around $50
Part number, 221-589-01-33-00 provided by Rudeney here.
Alex.
If you need an accumulator I'll sell you a new one still in its unopened package which I got from Newparts.com a few weeks ago. I think $120 and I pay shipping to you is a fair price. Send me a PM if interested.
I also have one or two spare instrument cluster LCDs...
I will run this test. Then I'll know better if I need accumulator/dampener. As for the LCD, as I said, it cured itself with no human intervention. We'll see for how long it is going to behave. At this point it is all a moot point, since car is on the lift getting maintenance done. When finished, I am planning on posting lessons learned. And there is a lot of lessons. If I ever meet a guy, who wrote MB WIS .... Not to mention the guy, who designed some of the parts.
I this case I’ll agree that in the less experience hand the 230 tool may be a better option.
Mike.
Mike.
EDIT - After seeing the car sag I got into the habit of lowering the ABS when I park. I think that it is kinder to the system.
