SL/R230: Sl600 ac clog up, maybe the condensor or expansion valve clog up
so reapair everything in ac is 2,583 or 1,234 without compressor (both including labor and parts)
But an entire system failure seems high unlikely so im hoping its one of the other (condensor or expansion vavle)
also should i take my car to a mercedes specialist just for ac refill, because it might need the star commands to reboot the ac.
so thinking of replacing the ac condensor and expansion vavles myself, anything i need to know before doing so, and do i need to restart the ac system with a star diagnosis.
condensor online around 80$
expansion valve around 40$
Anybody done it and what are yall thoughts.
I have the star system, but it does not provide low side pressure, so hard to tell if the compressor was working properly (the gauge on the refill bottle is junk).
I used a 25% off coupon and bought a gauge set at Harbor Freight. It confirmed low pressure differential. So, compressor time.
Replaced the compressor (and accumulator, again).
AC now blows icy cold.
My symptoms are not the same as yours, so not saying you need a compressor.
The expansion valve is not hard. It is easiest if you remove the steel panel right behind the throttle body. No need to mess with the wipers or heater hoses (as the WIS instructs).
I did not change the condenser. I wanted to disconnect the hoses from it to facilitate the compressor change, but that hose manifold block was frozen in place on the condenser. I gave up, but was able to do the compressor swap anyway.
If you can get the hose manifold block off, the rest of the condenser change should be a piece of cake.
For the money, I would say replace both the expansion valve and condenser. That way you only pay for one accumulator and AC charge (although the freon is a negligible cost).
If I took my R230 to a shop called "Precision Tune Auto Care" which I presume handles multiple makes, then my expectations for getting an accurate diagnosis for any major problem would be fairly low.
I suggest you buy a pair of gauges and diagnose the problem yourself, or you take the car to an independent Mercedes tech who has the requisite understanding of how the system works.
so how long does it take to replace the ac compressor,
but the main question for me when i replace these parts do i need the star diagnostics to reinitialize the AC system, or just have it recharge at a shop and it will come ba
If you do not turn the climate control on in the course of doing your work, then I presume you won't set a fault code and will not need Star Diagnosis to clear a fault.
I've long held the notion that I would prefer to own a '600 instead of a '55, Alex, but with various repair jobs requiring more time and effort with the V-12 car, my enthusiasm for switching chassis is diminished.
left is old
left is old
left is old
