SL/R230: R230 Sat Nav Unit Installation
Old Nov 19, 2019 | 04:06 PM
Narday's Avatar
Mercedes SL350 R230
Hey all
Can anyone please guide me with installing a OEM sat nav? I currently have the tape player
Anyone in the west midlands area uk? Supply / fit?
Old Nov 19, 2019 | 04:14 PM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
Dudeman said he has a used Comand for sale, yesterday.
Old Nov 19, 2019 | 09:22 PM
Dudeman's Avatar
Current: '07 SL550 & '14 GLK350. Previously owned: '06 ML350, '05 SL500, '99 ML320 & '98 SLK230 (RI
First it depends on what model year SL this is.
Second, on the 05 and later models, the SAT/NAV is not part of the Comand unit, rather it's a separate unit that looks like an external Optical drive, and is installed in the trunk. It uses a DVD navigation maps, and does all the GPS processing. It sends all the Map data and GPS location information to the Comand Unit for display via MOST bus.
So if you're looking for a SAT/NAV unit and you have a 2005 and later, you'll need to be looking for that unit I mentioned above. Here is a link to a installation/retrofit how to:
https://mbworld.org/forums/w211-amg/...tion-pics.html
If on the other hand you have one of the earlier SL models (2003 -2004), which had the Comand 2.0 with a 4:3 screen. Those units were integrated, and the navigation processor was in the head unit.
Here is what the Comand 2.0 looks like:
Old Nov 20, 2019 | 01:52 AM
I have the 2005 NTG-1 unit. I think the older unit is a typical original design, totally matching the car’s soft lines. The embedding in the wooden surround, the cushion like buttons, well done, Deutschland. I have the larger screen but the overall design was flattened, as design changes often go. Dixit.
Old Nov 20, 2019 | 04:16 AM
Narday's Avatar
Mercedes SL350 R230
Right ok - I have the 2003 model, r230. What next?
Old Nov 20, 2019 | 09:55 AM
Dudeman's Avatar
What happens when you press NAV? Do you get a message of sorts? Does it say something like "No Navigation disc", or "Insert Navigation Disc"?
If not, or if you just get a compass, then most likely there is no navigation processor, so you'd have to replace head unit with one that has navigation. You will also need an antenna with a FAKRA connector.
Needless to say, you will also need some map discs, which are on CD for this system, so they cover relatively small portions, which means you'll have to have multiple CDs to cover a larger portion of the EU. But let me say this, the latest maps available for this system are way out of date, 2008 I think are the latest available.
My suggestion is to buy an aftermarket radio and do a complete revamp of the entertainment system.
Old Nov 20, 2019 | 03:02 PM
A1EK is thinking about swapping his unit for something modern. His car is from 2004. He resides in the UK.
