SL/R230: CTEK CTX Battery Sense (Bluetooth Battery Monitor)
It can be found here on CTEK's website: https://www.ctek.com/products/vehicle/ctx-battery-sense
Is anyone using this? I like gadgets and this seemed interesting since I don't drive my R230 as much during the winter months (and it would be neat to get an alert to remind me to plug it in to a battery maintainer in case I forget. However, I'm not sure this battery monitor would be that useful? Because it operates via Bluetooth, I'm assuming you wouldn't get any alerts of a problem until you are within 10 or 15 feet from your car (or about to get in your car), and getting an alert about the status of your battery at that point seems kind of useless since you will know the status of the battery when you get in and turn the key? Am I missing something here? I guess if you were walking by or got close to your car and your phone happen to connect, then you might get an alert?
I just thought this was interesting and thought I would ask the consensus of the group and see if anyone had any experience.
Lee
https://www.ctek.com/storage/ma/8584...-low-UK-EN.pdf
the gadget stores data for you. Common sense would probably suffice also, but I could see the logic in getting one, for the fun of it. If the cig. lighter is on power during cranking, a simple volt meter in there would be reasonably informative also, I think.
