SL/R230: Forgot lights on 5 hours, won't start
2005 SL 500. After 5 hours lights left on not running, won't start. road assist says alternator bad and not charging batteries. Is this common or does alternator stop charging batteries if they get very low?
With the engine off you should see just over 12V on the terminals and then around 14V after you start the car. Check both batteries, front and back to make sure there is no break in the connection somewhere along the way. Not getting the 14V, not to worry. Check the brushes they are probably worn out, or replace the whole regulator for few more bucks. You can do it! Even if you have never done this before!
jdub907 (01-04-2020)
jdub907 (01-06-2020)
Thank you. It's a $35 part at Pelican Parts. I bought an alternator assembly. Maybe I'll replace both to ensure internals of alternator are good (brushes, bearings). I have a mechanic checking it for me. He's not a Merc tech but a former engineer and very good mechanic who researches well. I recommend him to anyone in south mississippi. Worse case, I'll take it to my indy for further diagnosis.
Thanks for the help.
Thank you all for your responses.
Unless you drive the car daily, I highly recommend keeping it on a battery maintainer. I rarely drive mine and keep both the front and back batteries on separate CTEK maintainers.
