SL/R230: PSE pump - essential?
I hope this helps.
Rob
If the answer ,as i assume is NO it will not work at all , then is there a purely mechanical way of fooling/tricking it down , i have seen the emergency Roof UP video that shows various ways of getting the Trunk out of the way , wish i knew that before i stripped the boot carpets,lol . Is there also a way to put it Down ??
However on opening the PSE pump up the problem on mine was only a shattered impeller and the repair was straightforward. You can get the PSE pump out and open for examination in about 30 mins maximum, so I’d highly recommend doing that to investigate. If it shows water ingress and corrosion that may not be so straightforward.
I would really like to see if theres a fully Mechanical "only " way of putting oit down too , im bored and fancy seeing it opened up , especially if i dont have to buy a pump to do it !
Anyone got a cheap one ??
The reason your roof does not work is because the trunk partition switch is wired to the PSE pump. Absent a pump, the roof controller does not receive a signal that the partition is closed. And since the signal from the PSE comes over the CAN, there is no way to substitute for the pump.
Im not disputing what you’re saying, just reporting what I experienced. As soon as I repaired the PSE pump everything restored to normality.
Tony, at this point you may feel it is a risk to purchase a non-working pump. You can't do the experiment that I suggested which proves a pump needn't function mechanically. But there is another tell.
When you are driving do you get a message in the instrument cluster telling you to close the trunk lid? And is the little red LED on the trunk release switch lit? If neither case, then you know the roof controller is receiving a status that the trunk lid is completely closed, and you can have complete confidence that a broken pump can work. There is the caveat, though, that the pump must still function electrically, of course.
My Questions till stands tho , is there a purely mechanical way of putting the roof down , is it the reverse of the putting it up Video , slacken pump , undo the catches in the boot etc .
