SL/R230: How to remove the rear R230 struts easily within minutes - instructions
Instead, the strut should be removed FROM THE OPPOSITE END OF THE ARM as follows:
1) With the car on jack stands and wheel removed release the hydraulic pressure (if any) at the bleed nipple, disconnect the oil line at the strut by pulling by hand the quick connect (cover the ends to avoid contamination), disconnect the height sensor at the lower arm supporting the strut with 10mm socket and 8 mm spanner
2) Remove 3 bolts: the bolt attaching bottom of the strut to the arm, bolt connecting the stabilizer bar (top rear of the suspension sideways bar) to the wheel hub, and the bolt attaching the arm to the subframe. You are removing the stabilizer bar bolt only so you can push on the bar by hand to clear the arm to subframe bolt for withdrawal. It’s helpful to support the arm with a small hydraulic jack to release any pressure on the bolts when withdrawing them and later for reassembly to re-align them.
3) Pull the corner of the carpet in the trunk above the strut by hand to exposure top of the strut. Disconnect electrical connector and remove 2 bolts holding the strut. When finishing bolt removal with one hand, hold the strut with the other hand so it does not just drop on the floor but is lowered gently. That’s it.
Reasembly is the reverse. Note how easily and smoothly the arm to subframe bushing is aligned for the bolt with a small jack (up/down) and pushing on the brake rotor (in/out). I also apply blue LockTite on all bolts. Torque to specs.
With everything prepared and wheel removed the strut removal takes literally minutes and requires no physical strength (if bolts are frozen there is enough room for impact wrenches or extension handles). Of course use at your own risk and consult a professional if you don’t normally work on cars.
Here is a photo of the arm already dropped and strut removed (ignore missing brake disk removed for other reasons)
This is the stabilizer bar (left) disconnected at the hub (right)
This is the carpet pulled back to show the top of the strut.
Because if it is, then the new method presented here wouldn't be optimal... Or more precisely: You would have to cope with that in some way.
Related - two things I'm struggling with. My drivers rear strut is dripping oil at this point, so I need to replace. My passenger rear is completely dry. Both are original parts. (1) If I go with Arnott, do I really need to change both sides? Based on my understanding, if I only want to replace one side, I need to use a MB strut, which essentially is the same cost as 2 Arnott struts. And I've heard Arnott struts tend to ride a little firmer? (2) Has anyone replaced the struts and NOT have to had performed a Rodeo? When my car has been in storage, it's dropped to the point where I'd imagine a new strut would be upon initial installation. Upon start-up, the car levels right off and all's good. Wouldn't the new strut just "fill" back up and level off, similarly? Where I could raise/lower the car (similar to what I did when I flushed the system not too long ago), and monitor fluid level?
I will let others comment on the remaining questions. .. ...
Front: https://www.youtube.com/watch?v=Q4t-...ature=youtu.be
Rear: https://www.youtube.com/watch?v=rdth...ature=youtu.be
I have an R231 but, I'm helping a buddy with his R230 ABC strut and accumulator replacements.
Great tutorial on rear strut removal and following Arnott video seems front easy as well but, I do have a question relating to amount of system fluid loss per strut............................................. and best method for replacement of fluid when doing 1 or more than 1 strut....................................also is it necessary to have a "star" system to replace the struts and fluid..........................................?
Few more question relative to the accumulators....is their replacement as easy as the struts............................................ .., anything to watch for..........................................., should we replace the pulsation damper as well as the F & R accumulator...................................... and again question regarding fluid replacement................................. and OK to do without a "Star".............................?
Maybe one more question: While we at it should we replace any hydraulic line or lines that are most likely to fail.................?
Nothing that would indicate the pump or valve blocks are an issue so plan to leave them alone.
Final question: Of course we will do a filter and fluid change with the new 10 micron filter; thinking of cleaning out the canister with a turkey baster, installing a new filter and fluid doing body movements up and down and riding the car for a number of miles then another clean-out of the canister and new filter and new fluid........sound like good way to go......?
Appreciate any help with my questions above.
THANKS, Steve
Make sure to wear eye protection and disposable clothes as you may get fluid sprayed even if you think the pressure has been released (ask me how I know).
STAR is for the rodeo and such but I think the system should bleed itself after some driving and suspension up/downs (keep checking the fluid).
I don't know about the accumulators on this car but I changed them on a different Mercedes (wagon) and it was quite easy. You know they are bad if the ride becomes bouncy and fluid level goes down - gas inside the accumulators gets replaced with the fluid and does not absorb shocks.
For hoses - if you want to be safe change them ALL! No kidding, I recently had a hose rapture on my car while driving, like I hear a gun shot, the car drops down by a few inches on one side and immediately I become stranded (at night in my case) - the car becomes undriveable. That did it for me and I threw out the ABC and installed coilovers - will write up on that soon.
https://mbworld.org/forums/m275-v12-...on-thread.html
Had a successful day replacing my drivers side rear strut using this "new" (er) method of removing the inner control arm bolt. Overall it wasn't bad with An extra set of hands to maneuver a second jack under the control arm at certain times. Luckily my car is rust free- every bolt loosened right up, even the exhaust hangers. I had to drop the exhaust at three points to clear removal of the inner control arm bolt towards the rear. The quick disconnect was a little tricky- just had to work some WD40 into it to get it to fully release.
Buttoned her back up, topped off the ABC reservoir, started the car and raised and lowered it half dozen times. No leaks, no lights. Haven't driven her yet but hopefully this indicates I'm in good shape.
This was always a job I've been intimidated by, and I'm very experienced w car repairs. I'm very happy with how the process went. Got an Arnott strut from summit for a good price too.
But I'm surprised with your comment: "I had to drop the exhaust at three points to clear removal of the inner control arm bolt towards the rear." Sorry if that point of my instructions was not clear, but I never had to touch the exhaust - if we are talking about the same bolt, it came out easily after:
1) Disconnecting the stabilizer bar as shown on the photo titled "This is the stabilizer bar (left) disconnected at the hub (right)" above
2) Pushing the stabilizer bar down by hand from the outer side, as it pivots on the inner (at the car center) side and clears the arm bolt for withdrawal
There should only be a total of 5 nuts to remove - 2 for the suspension and 3 (one at the bottom and two at the top) for the strut itself. All 5 easy to access and easy to undo unless the car is rusty. Or perhaps your car is different than mine 2003 SL500? In any case the job is completed so in one sense it does not matter for this case, but for the benefit of others and to keep it as simple as possible - could you please elaborate exactly why you had to do it? Thanks!
All the parts in total for the complete conversion, including top of the line, multi-adjustable coil over struts, cost $39.00 (thirty nine US dollars, this is not a joke or a miss-print and includes parts and all the shipping etc costs in continental US - it's $39.00). Plus the labor and access to a STAR system or similar for electronics re-configuration. You can also ignore re-configuration, the car drives the same either way, just gives red ABC alarms without reconfiguration. Here are the details, thanks
https://mbworld.org/forums/sl-class-...er-struts.html
I know I mentioned, but that quick release was pretty stuck. Luckily after WD, and rotating, it started to slide more and more. You could see the red from the rust when spraying it down. It was equally tricky to re-install. I couldn't get that resolving "click" when re-installing, eventually, I knew it was on there- I was able to push the line in and out and felt the lock.
Happy to answer any other questions. This was a fantastic technique you posted.
Cheers
