SL/R230: I spilled tranny fluid everywhere - help needed
I spilled tranny fluid after changing my radiator I forgot to install oil cooler hoses, started engine and started adding coolant then saw a huge puddle, I must of spilled 3 quarts of fluid. How do I top up the tranny fluid and check level?
also the fluid is black, shouldn't it be red brown?
can I start the car with no tranny fluid and just leave it in park is this fine? Where is tranny oil reservoir? Any and all help appreciated. see pictures.
I would change transmission oil filter, oil at a minimum.
Assuming you have the older seven speed, you did not say.
In addition I would also change oil pan{ if you transmission has the older pan, as the new pan has a larger oil capaticy. As you would have to remove the pan to change the oil filter.
The bolts on the pan are single use torque to yield bolts. You would require new bolts
You would need an oil filling adapter and pump to refill.
I changed the oil in my 7 speed two weeks ago, purchased a kit from FCP euro, 7 speed upgrade kit{ oil, new style oil filter, new deeper pan, new overfill tube, new gasket, six new bolts and new copper seal] for around $225.00
You would also need a scanner or dip stick tool to measure level.
Will try to post generic instructions from WIS, can not do that from a phone right now.
Joseph~
__________________________________________________ ______________________________
There are many choices for DAS/Xentry Diagnostics for MB.
Ensure you have the right information before getting one. There is too much misleading info.
I’m a forum member and programmer who’s learned the hard way. PM me if you have any questions.
Of course if you are doing this in conjunction with dropping the pan to change the filter, you put in about 9.5 - 10 quarts of fluid after installing the pan and draining the torque converter. If there is not torque converter drain, then put in 5 - 5.5 quarts. Then you check the flow rate at 113F.
Still funny though.
Anyway, I have exact same setup on my 05. I bought the new transmission pan, actually the transmission service kit from FCP. It comes with all parts needed. If you plan on doing the complete flush then order an extra gallon of fluid. I’ve chosen to put a container (actually 2of them) in a closed loop before the cooler. First one was empty, second contained the fresh fluid. It will be fairly easy for you since you have all the hoses disconnected.
By the look of the current state of the fluid I would also get an extra filter for the initial flush. Your old one is probably quite clogged and it will just contaminate fresh fluid.
So, drain the pan.
Remove, clean and replace the filter.
Put the old pan on with old seal and bolts but only hand thigh. Do not torque the old bolts! Pan is only there temporarily.
Fill the fluid from the bottom, and close the plug or the valve if you are using one.
Start the motor and you will see the fluid fill the empty container you have setup earlier. It happens fast, be ready to shut it off.
Disconnect all the extra contraptions from the cooler lines.
This time don’t forget to attach the hoses to the cooler 😀
Drain the pan again.
Remove the pan.
Remove and replace the filter again.
Install new pan with new seal and new bolts.
Follow the PDF from above to set the proper level.
PS;
Our car does not have the drain plug on the torque converter. For some reason there is a small plate factory welded over where the drain plug would be. From what I researched so far it was only the case with 05 models.
Hope this helps
Good luck
Still funny though.
So, drain the pan.
Remove the pan.
PS;
Hope this helps
Good luck
Sorry I'm having trouble understanding, I'm not very experienced doing this. What do you mean by closed loop?
There are 2 hoses that connect into the radiator, do both of them have to be put into the empty container?
does your method get rid of the old fluid in torque converter?
Also is it absolutely necessary I upgrade to the new pan, ai haven't found any reason why the new one is better.
Also I found a lot of little metal shavings inside the old fluid, is this normal?
Thanks a lot
New pan has close to the same capacity but is design for better flow.
Since you have metal shavings a complete system flush is a must.
Let Rodney comment on it though.
Also can I have the engine running in park while I work elsewhere on the the car until I get the tranny kit in the mail or will this damage the tranny at all
You will probably need more than a gallon of extra fluid due to current situation (system contamination).
lets hope there is no major damage to the transmission.
When your torque converter does not have a drain, you have two options for doing a "full" fluid change that will get the fluid out of the torque converter. One, you can drain what you can from the pan (about 4.5 quarts), change the filter and and refill. Then do three cycles of driving about 100 miles, daring the fluid and refill. That will have you changing close to 95% of the old fluid out for new. Since you have to drop the pan each time (to deal with the overflow tube), you would technically need a new gasket and bolts each time, but you can probably get away with only using new parts for the last pan drop.
The other option is to do a flush by detaching the transmission cooler lines. The outlet line is put into a bucket to collect the old fluid as it is expelled, and the suction line is in another bucket full of clean, new fluid to pull it in. I don;t have the documents for the 722.9, but here are the ones for the 722.6:
http://benzbits.com/722_6/TransmissionFlush.pdf
I think it's pretty much the same except that the fittings on the 722.9 are different. Most people find a way to fashion some rubber hoses to the cooling lines to make this easier. There is also the question of when to change the filter, which should be done after the flush, which means you need another 4-5 quarts for refilling after that.
Now, having said all that, since you've already dumped a bunch of fluid from the cooling lines, I'd go with the first option. The first thing you need to do is replace the filter and and properly refill and set the level. Instructions for that have already been posted. i suggest buying the proper screw-in adapter for the drain plug. You can buy a nice Assenmacher pump that comes with the adapter and a shut-off valve, or just buy the adapter and use a cheap Harbor Freight fluid transfer hand pump. Since you probably have the older pan style, you need a new pan and a new overflow tube. My advice there is just buy a kit that includes those items plus the bolts and gasket.
