SL/R230: 2004 CLK AMG vs 2004 SL AMG
the CLK was better in terms of handling for sure, but the SL is better in every other way.
a lot more in maintenance and issues with the SL...hardtop and ABC being the biggest
also clk is I believe 3500-3800 pounds? I had mine corner balanced with a 50/50 weight distribution. The SL is 4200?
The SL with the Supercharger.
The CLK is a heavier car. It handles well for a heavy 16 year old car.
What I am trying to discern is whether the SL is a better car and in what way. I know it has more horsepower and is lighter. It also has more curb appeal. But is there anything else. Does the SL handle better?
Appreciate the feedback.
The difference in the two cars is great. While I always though the CLK felt planted and solid, the SL is even more so. It literally feels like you are driving a solid brick. Nothing flexes, nothing rattles or jostles. Part of this is the extra chassis stiffening members. This comes at a cost, though, as you have a much taller and deeper door sill to step over. ABC helps, too, as it make s HUGE difference. I can take a tight freeway ramp ant high speed and stay flat, and then run down a rough road without being jostled to death. There is ZERO squat or dive on takeoff and braking.
As for maintenance, yes, ABC will need some. It will be more costly to maintain the SL than the CLK in that respect, but much else is the same, just typical MBZ issues. I'm biased, but I say go for it.
Only 2 #’s make a true G
We owned an 04 W208 CLK. Cabriolet. 2004 was a year MB made the Cabriolet 208 and the W209 Coupe There’s no true AMG W208’s unless you have a 55 not 430, 320 which OP left anonymous
Had it before we got our R230. The two are in a completely different realms.
CLK W208 4 seater, fairly decent trunk 4.3L V8 w 5speed auto conventional suspension, no rack and pinion just old pitman arm/steering box
SL R230. 2 seater slightly larger trunk 5.0 L V8w 7speed hydraulic adjustable suspension
Would I rate one better? No, just uniquely different
Thought I’d ask the board first for comparison.
It’s a long drive to see it ;-)
The 2004 CLK 55 AMG is a 209. It does the 0-60 in 4.5 and it’s a 5.4 liter. Almost 5.5 liter. 362 Hp.
Regarding ragtops on sports car. Had a 911 and an S2000 which were both ragtops and now this CLK.
Not bad actually. Not as quiet as a coupe or the SL.
Don’t know if the SL develops rattles over the years.
Cheers
Regarding ragtops on sports car. I’ve had a 911 and an S2000 which were both ragtops and now this CLK. Not bad actually. Not as quiet as a coupe or the SL.
Cheers
Cheers
Clk is a nice car (CLK63 blackseries one of my favs)
but the sl is a great car, and when you get into the high powered versions, it makes these new sportcars with little engines look like jokes
And maintenance isn't that bad, Its what you'll expect with having a 500hp mercedes, 911's, zo6, gt500, hellcat, ferraris, viper, lambo,m5, maclaren all have significant maintenance cost over your everyday car.
