SL/R230: Disconnected Roof tube, pls help
I removed my spare wheel last night and I must have done something to the roof connections. I have a 2009 SL550.
This morning I lowered the roof and drove to work and I could smell something like wires burning. Now the roof won't close. Windows go down, I can hear the motor running but roof won't budge. Also the trunk won't open automatically, I have to push it up.
I removed the spare wheel again and saw that a transparent tube on the right side, close the the battery, is connected at the top of the battery but not at the bottom. (see picture). Can someone tell me where I need to plug this in and if this is likely the cause of the top and trunk not working. As the top is down I can't really see where the tube goes, it's a tight fit.
Now I need to figure out what could cause the malfunction. I'll scour the forums a bit more. I noticed that the fluid on the left hand side is at half point.
A roof not working while the pump is running can indicate a leaking cylinder, internally (no fluid loss) or externally (fluid loss). But it seems your problem has come up too sudden.
We need someone more knowledgeable to chime in on all this.
