SL/R230: Forever FIX off your ABC issues and engine oil use
Old Apr 16, 2023 | 02:14 PM
  #151
maxorbit's Avatar
300E
Update success
Originally Posted by maxorbit
I just added some QMI hydraulic sealer to my sl500 system. I ordered the liquid from Norway, the same ppl who make Royal Purple lubricant.The container was sent regular post and only cost $10 for shipping and it took less than 3 weeks to arrive. I'll report my findings in a few days. I also received my refurbished valve block in case I need it
It's been a few days since I added the QMI stop leak and it seems to have worked in my case. The car was diagnosed with an internal leak probably at the front valve block
Ususally in the am the car would lean to the drivers side and there was no clearance between the tire and fender lip. Now after sitting all day yesterday and during the nite that leak seems to be gone. The car no longer leans and I can put 2 fingers between the tire and fender lip !! I don't know how long long it will last but it's all good now!! I ordered the fluid from Norway and had it sent regular mail it only took about 3 weeks. It's well worth the cost to give it a try.
Old Apr 18, 2023 | 09:34 AM
  #152
Dirtleg13's Avatar
2003 SL500
Well just found a weeping strut yesterday. Ordered a bottle from Norway. We'll see what happens.
Car sat for almost 7 years and I'm sure that's what caused the leak.
New strut will happen if this doesn't work.
I'll make an update when I have tested the QMI product and have some results.
And for anyone who wants to know where to get it in Norway, here is the link. QMI Site
Old May 10, 2023 | 01:29 PM
  #153
Tommyboy928's Avatar
89 SL500 Silver ,97 SL500 Carlsson 04 Mercedes SL55 AMG , 07 Mercedes SL55 AMG convertedBlack series
here is a company that use the orginal QMI recipe, and they say they sell thru their web page, for the guys that could not order other places USA . https://www.truebrandproducts.com/universal-stop-leak/
Old May 10, 2023 | 10:44 PM
  #154
theboogers's Avatar
2020 S560,14 ml350, 03 sl55, silver, pano, slr cams, evo headers, lsd, 2019 s63 cab.
found it takes you to amazon for purchase.
Old Jun 3, 2023 | 06:30 PM
  #155
How did it go , did you manage fix it ? Sitting still 7 years is worse than anything .
Old Jul 12, 2023 | 04:26 PM
  #156
bneinast's Avatar
2002 CL500, 2003 SL55
Two months ago I put it in my Variable Roof hydraulics on SL55. It had leaked a lot of fluid and wouldn't go all the way up. Seems to be working great with no leaks so far. Also, put it in my CL500 ABC and seems good. Waiting few months before putting it in SL55 ABC. I noticed an ad from somewhere that states specifically for Mercedes ABC.
Old Nov 14, 2023 | 08:23 AM
  #157
bneinast , no need wait for add SL55 , they all old now, and rubber seals all over the place inside,including hoses that dry up an crack need little help , your powersteering also add 40 ml to protect system.
Old Feb 13, 2024 | 10:25 AM
  #158
Boo2boy's Avatar
SL55 AMG
Hey all, new here. Great info. Just ordered the True Brand stuff, can’t wait!!!
Old Feb 15, 2024 | 05:21 PM
  #159
V12orWalk's Avatar
2005 CL600 Renntech Stage 2
@mikerx80 How did this work in your Lexus?
Old Feb 16, 2024 | 11:14 AM
  #160
How did it go with your leaking struit ? was it fixed ?
Old Mar 8, 2024 | 12:33 PM
  #161
V12orWalk's Avatar
How did it work out for you? @Boo2boy
Old Mar 8, 2024 | 02:14 PM
  #162
Boo2boy's Avatar
SL55 AMG
I used it at the same time I did a fluid flush on the ABC system. Prior to this, would get the ABC warning to visit workshop when driving hard, but ever since I did the flush and added a bottle of this stuff, haven’t had any lights come up and I’ve been driving the car harder than ever!!!! I’d say works like magic!
Old Mar 27, 2024 | 07:37 AM
  #163
GVP444's Avatar
2002 R230 SL500
Question
Hi All
Is this stuff even available anymore? I cant seem to find any available. Is there anything else that can be used in the engine and ABC system? I have inherited my uncles 2002 SL500 and want to make sure all seals etc are refreshed?
I am in the UK though so products may differ
Old Apr 14, 2024 | 10:03 AM
  #164
Originally Posted by GVP444
Hi All
Hi, i know some has bought from Norway dealer qmi.no Norway and shipped to UK. Also spanish dealer has the stuff qmi.es , just amazing its no dealers in UK for sutch super product , not just for fix the leaks ABC , but engine teflon treatment is just super for protect engine moving parts, and also keep rear main seals in good condition.
Old May 24, 2024 | 02:28 PM
  #165
porscheguy's Avatar
2004 SL55 AMG
finally looked to the end of this thread. I have a slight leak in my top hydraulics, takes several up/down cycles to loose enough to stop working. so far I have not found the source of leak. have not pulled out all the covers in the trunk.
it sent me to amazon to order. how much should I add next time my top reservoir is low? what you get is 3.4oz
Old May 24, 2024 | 03:27 PM
  #166
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
My recommendation is to add 0 oz.
Old May 25, 2024 | 06:13 PM
  #167
can add 60 to 70 ml , but issue is get the stuff to the seals , if seals are cracked , it will not work, but will help all other seals that is not cracked . would be good idea change the oil in system also. 20 year old oil, not good.
Old May 25, 2024 | 07:09 PM
  #168
porscheguy's Avatar
2004 SL55 AMG
thanks. recall I have been losing fluid constantly. takes several cycles of top up/down to lose enough that causes it to stop moving, up or down. seems I only have to add a few oz to bring back to the top mark on the tank. surprised I have not yet found where it is going. still need to pull out all the panels in the trunk.
so if I drain the reservoir only and refill with fresh fluid, is that enough? I would suspect the fresh fluid would find its way to the leak.
but willing to fully drain the system. any suggestion on the best way to fully drain and replace the fluid? then add the stuff to the new fill.
Old May 25, 2024 | 07:39 PM
  #169
your leak can be roll over system behind the seats, is some people that made some info about this . if you can see the leak, is probaly there, and oil will be down below. is fairly easy to change seals they say.
Old May 25, 2024 | 07:41 PM
  #170
Find me a SL55 that not use oil, like my car, is around 5 years now, i cant detect any oil use , stopped long time ago have extra oil in trunk for long trips.
Old May 26, 2024 | 09:31 AM
  #171
porscheguy's Avatar
2004 SL55 AMG
Hmmm.....
problem is I have not found source of leak. suspect it is hiding somewhere behind covers. but over so much time just cant understand why I have not found it coming out somewhere. I have heard it is easy to replace seals .... if I can find location.
no suggestion about draining system and refill? so will just drain the reservoir and refill with the amount of sealer added before. hoping the sealer will find its way to the leak...
Old Jun 8, 2024 | 04:51 PM
  #172
porscheguy's Avatar
2004 SL55 AMG
got sealer and ordered more Pentosis.
HOW DO I REMOVE THE EXISTING FLUID FROM THE ROOF'S TANK??????
Old Jul 24, 2024 | 09:52 PM
  #173
Old Jul 25, 2024 | 08:31 AM
  #174
porscheguy's Avatar
2004 SL55 AMG
thanks but this does not appear to remove old fluid.
the technique I saw removed the second plug that let the air escape as I added fluid. has work good so far.
I tried adding the stop leak suggested when the level dropped to where the roof would not work and it has not stopped the small leak. it appears to work as described since the rubber tip of the fluid syringe I used swelled up so much it is no longer usable.
read threads about finding source of leak. since I have never seen any sign of fluid anywhere accessible, I am suspecting it is on the parts in front of the rear wheels next to the rear panels and storage shelf. looked like a lot of work to get them out, but in that video that is where the guy found the leak.
going to finish the fusing of the BCM first.
despite these minor issues I really LOVE this car. an incredible, angry beast.
Old Jul 25, 2024 | 11:50 AM
  #175
MikeJ65's Avatar
Those softened seals will also see much more abrasion wear on the other 10 cylinders which hadn't been leaking, which is why they were not spec'd that soft to begin with. I would rebuild all of them and this point and probably the pump too.
