SL/R230: How many oil drain plugs on a '55?
Old Feb 28, 2020 | 04:32 PM
Seven Out's Avatar
2003 SL500, 1991 500SL
There's a thread going on the AMG forum, and someone says they found two oil drain plugs. One on the left and one on the right? I don't have a '55 but I was wondering if this is the case.
Old Feb 28, 2020 | 05:13 PM
pmercury's Avatar
member
CL
stock both of the 230472 and 230474 models have 2
Old Feb 28, 2020 | 05:20 PM
pmercury's Avatar
member
CL
there are also aftermarket with 2
Old Feb 28, 2020 | 06:02 PM
GBsSL55's Avatar
2004 SL55
Hey Seven, I think you are thinking of the tread I posted in over on SL55AMG. Searching on the WWW shows many mentions of the 55 compressor motor having two factory drain plugs....one on the left side, and one on the rear. Benz World has a few threads on it. Two sumps/plugs because there is a crossmember going between the two sumps.
Old Feb 28, 2020 | 06:08 PM
Seven Out's Avatar
I certainly was referring to your thread. Thank you for that response.
Old Feb 28, 2020 | 06:15 PM
pmercury's Avatar
member
CL
what model number is that ? not a R230 yes ?
Old Feb 28, 2020 | 06:20 PM
GBsSL55's Avatar
2004 SL55
2004 SL55 AMG
Took a quick pic just now. That's the rear plug, and the second plug is on left side. Had to remove that panel held on by four 8mm bolts. Cant see that plug now because panel covers it up.
Old Feb 28, 2020 | 06:28 PM
pmercury's Avatar
member
CL
2004 SL55 AMG
right ! my fault, as usual the graphic did not show 2 but the partlist does
