SL/R230: Top trim
Old Mar 6, 2020 | 06:26 AM
gregorynp's Avatar
2022 GLS450
Top trim
Hi, A trim piece came off the cheap plastic clips. Any suggestions on how to fix?Thanks for your comments.
Old Mar 6, 2020 | 07:14 AM
pmercury's Avatar
member
CL
Old Mar 6, 2020 | 07:18 AM
gregorynp's Avatar
2022 GLS450
Thanks for the info. The clips are broken. Is that the part number on the file you posted?
Originally Posted by pmercury
Old Mar 6, 2020 | 07:33 AM
pmercury's Avatar
member
CL
no
Just go to the dealer, they have them in stock
or tell me if you need the part number
Old Mar 6, 2020 | 07:34 AM
gregorynp's Avatar
2022 GLS450
I would appreciate the part number as I am using an independent
THANKS
no
Old Mar 6, 2020 | 08:10 AM
pmercury's Avatar
member
CL
THANKS
I just tried to locate them but they are not with the flap
please call a dealer for the clips, guess they put them in a unusual place in EPC again
Old Mar 6, 2020 | 09:56 AM
seven_out's Avatar
SL500, Miata
That little flap breaks off on everyone's car for no apparent reason. It can not be purchased separately and is only had by purchasing the entire panel.
On the other R230 forums several solutions for repairing a broken flap have been discussed, and there is a seller on eBay of a repair kit. I do not know the I.D. of the seller, but he is mentioned in threads.
Old Mar 6, 2020 | 10:03 AM
pmercury's Avatar
member
CL
Lol, that's why I couldn't find them
can't he glue them back?
Old Mar 6, 2020 | 11:25 AM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
There’s heaps of info on this on the forum, on both repairs and prevention.
Notorious can’t-buy-separate item.
Look for ‘flaps’, ‘ears’, ‘trim pieces’ and similar.
Old Mar 7, 2020 | 04:25 AM
matk's Avatar
R230 350SL
In a word no. They have to hinge as part of the roof opening/closing process and once the hinges are bust that’s it.
There are various ways to try reattaching but glueing it back won’t work.
Old Mar 7, 2020 | 04:42 AM
pmercury's Avatar
member
CL
With glueing I mean special dual component cold soldering stuff you know, there are so many. but yes it looks like a nightmare
Old Mar 7, 2020 | 06:29 AM
gregorynp's Avatar
2022 GLS450
I have looked extensively and can't find anyone selling a solution
Old Mar 7, 2020 | 07:27 AM
https://mbworld.org/forums/sl-class-...er-called.html
Old Mar 7, 2020 | 09:06 AM
seven_out's Avatar
SL500, Miata
That's terrific. Far better than the Gorilla Tape solution I've seen.
