SL/R230: Trunk Shocks SL550 - Pls help
Hi all,
I tried to change the Trunk Shocks in my 2009 SL550 but failed miserably.
I managed to remove them alright but I can't lift the trunk high up enough to make the holes of the new shocks align.
My model is remote open so has an extra shock/hydraulic on each side. Do I need to remove these as well? If so how do I do that, the mechanism doesn't look straight forward.
Or is there another way to do this?
Hi all,
Any other ideas?
They are pressurised to lift the trunk. They should extend after you let off pressure. I don't have the power lifting trunk, so it may be different then mine.
alexisvx (04-05-2020)
Yea just dealt with this too and also had some issues, although I don’t have the powered trunk close option.
1) are your new strut identical to the old ones?
2) did you remove both struts before installing the new ones?
Im not sure if this will work as I’m thinking laterally here, reinstall the old struts and then lower the roof halfway and stop with the trunk vertical. Now go to the manual key lock in the truck and try the key in the lock to manually open the trunk.
the trunk should now swing back the other way but as the roof mechanism has already moved the trunk, you might find you now have a lot more space?
No idea if this works but worth a try? If you do this put a piece of wood between the windscreen frame and the lash edge of the roof as after a few minutes the roof might spring back into action and try to close on you.
See this video about 2.20 into it
alexisvx (04-04-2020)
https://youtu.be/4_l8WTeo34k
I have not replaced it on a MB but I have done it several times on others. I too had difficulty until I learned that you need to install the bolts at the top first and have someone push up on the trunk lid to get the bottom bolts in. You can’t compress them, it’s too hard to do.
There must be a problem being caused by the auto close components.
It was extremely easy on my car after the struts on both sides were removed prior to replacement. I also initially bought the wrong struts, there is a very similar one mounted elsewhere on the trunklid that is slightly longer and will not fit.
I’ll check WIS tomorrow in my free time (imagine that lol) and see if there are any special instructions for cars with auto close.
thank you again.
alexisvx (04-07-2020)
LOL. I used broom sticks to hold it open but it was still not possible. I do feel that I pushed all the way up but couldn't line them up. I'll take them to my mechanic and see if they can help. It's a bit embarrassing to go to them for something so simple but what can you do?
I took it to the mechanic and it ended being a 3 man job! Two people holding the trunk, one using a wrench and one placing the struts in. They told me that they had replaced hundreds of them and never experienced this! All is good now.
