SL/R230: Sometimes engine dies
Old Apr 16, 2020 | 05:27 AM
starfighter's Avatar
r230
2005 sl500
vehicle runs great......BUT..
every so often after running at speed, I stop for a traffic light and engine stumbles and sometimes dies.
doesn't happen every time, but often.
bad fuel ?
Appreciate any thoughts.
Old Apr 16, 2020 | 08:56 AM
sean65's Avatar
2004 SL500
There should be an error logged, no? Do you have an OBD2 reader?
Old Apr 16, 2020 | 09:09 AM
pmercury's Avatar
member
CL
yes, everything is logged and remains until battery is disconnect for a while
you need to run a proper diagnostic asap
Old Apr 16, 2020 | 09:13 AM
r230
No error message
I'll try hooking up my Foxwell
Old Apr 16, 2020 | 09:19 AM
pmercury's Avatar
member
CL
if you have a mess of fault codes in there, delete all, then on the next fail, immediately run that foxwell thing. that way you have a focused fault result
good luck !
Old Apr 16, 2020 | 09:35 AM
r230
No error message
Checked with my Foxwell
no fault codes...
was 1 relating to rear power supply and was an old one
Old Apr 16, 2020 | 09:37 AM
pmercury's Avatar
member
CL
no fault codes...
start checking your batteries then, and alternator
Old Apr 16, 2020 | 09:42 AM
GeeJayMaj's Avatar
2008 SL55AMG
Could it be Crank Shaft Sensor ?
Old Apr 16, 2020 | 09:46 AM
r230
Doesn't do it every time...
If it was an older vehicle I'd say a bad dashpot..
Old Apr 16, 2020 | 10:24 AM
seven_out's Avatar
SL500, Miata
It's easy to think of causes for an engine shutting off unexpectedly. In this case you need to consider which ones correlate with the particular circumstances. For me, there simply isn't enough detail in the first post.
Old Apr 16, 2020 | 02:01 PM
r230
Foumd
Old Apr 16, 2020 | 02:02 PM
r230
Found it
Air cleaner cover was loose
Old Apr 16, 2020 | 02:11 PM
pmercury's Avatar
member
CL
lool
I sometimes forget to fasten the turbo intercoolers hose, first acceleration, bang it pops
Old Apr 16, 2020 | 10:12 PM
sean65's Avatar
2004 SL500
That confuses me. The air cleaner cover is the engine cover. Even if it's loose, air is able to enter the intake, just possibly dirty. How does that shut down the engine?
Old Apr 17, 2020 | 06:58 AM
r230
Mass air
Sliding around sending different amounts of air to the mass air sensor.......but whatever.
properly reinstalling the cover fixed the problem........
