SL/R230: suspension noise
Old Apr 27, 2020 | 09:25 AM
imtheking's Avatar
Former R230, W220 and W221 owner
suspension noise
2003 Sl500
Had strutmaster- replaced all 4 struts and went back to ABC- both with strutmaster and ABC there is a rattling noise coming from the passenger side when going over bumps- not when you go over one bump but when you hit a roadway going over a bunch of bumps
I checked all the controls arms and bushings and it looks fine- is there a insert/bushing on the top/bottom of the car that the strut goes into? The sound is similar to like putting a penny into a small can and shaking it around- again this is only apparent going over many small bumps
Old Apr 27, 2020 | 11:17 AM
seven_out's Avatar
SL500, Miata
On early R230s the polyurethane (?) inside the lower control arm bushings was a bit too soft. This would cause noise when traversing gravel and other irregular surfaces. This was rectified with a harder bushing.
Possibly your car has the soft bushing. I know that cars as late as spring 2002 production had the soft bushing, still later cars may as well.
Old Apr 27, 2020 | 03:42 PM
imtheking's Avatar
Thanks Rod- I'll check it out
