SL/R230: No power to the seat and windows driver side
Old Apr 28, 2020 | 12:33 PM
SL502's Avatar
SL55AMG-CL55AMG
El power is gone on the driver side for seat and windows and mirror, and the vario roof is out too, No fuse blown, on fuse F9 tells me electronic fuse ? Anyone had this problem before ?
Old Apr 28, 2020 | 07:03 PM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
If you have described everything that does not work and not failed to mention significantly more, then I can not even guess at a diagnosis with the information on hand. You may find something on a wiring diagram; the complete set is here: R230 ETM 64. Ultimately, you may have no recourse but to use Star Diagnosis or Foxwell NT510.
Old Apr 29, 2020 | 03:11 AM
SL502's Avatar
SL55AMG-CL55AMG
Thanks bobterry99, need a Star or Foxwell Diagnosis this time .
Old Apr 30, 2020 | 03:48 AM
SL502's Avatar
SL55AMG-CL55AMG
My ICarsoft tells me a lot more ! Control unit N10/10 (Driver side Sam control modul) Is not transmitting data on the Can bus.
Control unit N22 (AAC `KLA` control and operating unit) Is not transmitting data on the Can bus
Control unit N10/8 (Rear SAM control modul) Is not transmitting data on the Can bus
Control unit N80 (Steering colomn modul) Is not transmitting data on the Can bus
Old Apr 30, 2020 | 06:32 AM
pmercury's Avatar
member
CL
compiled you a PDF to understand can
hope this helps
file to big as attachment, uploaded to one of my mega, here is the link:
https://mega.nz/file/ge51ACyQ#DH6OsS...ou54305N5NBI8M
Old Apr 30, 2020 | 07:25 AM
SL502's Avatar
SL55AMG-CL55AMG
Thanks pmercury, trying to make it.
Old Apr 30, 2020 | 08:21 AM
bobterry99's Avatar
My ICarsoft tells me a lot more ! Control unit N10/10 (Driver side Sam control modul) Is not transmitting data on the Can bus...
Since you have iCarsoft, you likely do not need anything more at this time.
"...is not transmitting data on the CAN..." faults are typically set when the car has been idle, and the rear battery voltage is low. In these instances they can be ignored. If iCarsoft distinguishes currently active faults from ones which were active in the past as Star Diagnosis does, then you may find these faults are not current, and if you erase them they do not return.
Old Apr 30, 2020 | 11:23 AM
SL502's Avatar
SL55AMG-CL55AMG
Thumbs up
Thanks bobterry99, I`m still in Norway but the roads are dry so I need to drive this car a good distance and take a check after the trip
