SL/R230: Electrical, no low beams, no fog lights, SAM?
Hello. I had both batteries disconnected for a while when the car was in storage, I needed to replace the front battery. 2007 SL 550
Now I have no low beams and no fog lights. Also heavy drain at the rear. When scanning for codes I am unable to connect to front passenger side SAM,, I wonder if there is a pre fuse somewhere that I need to check? Any suggestions on what to do?
The weather just got SL compatible here in Scandinavia and this electrical mystery is really getting me down.
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
Likely a 200-amp prefuse in the passenger footwell is blown or the passenger SAM is defective. If you pull the fuse and relay block along with passenger SAM out of their housing you will find a 16 mm red cable supplying power from the prefuse. I'd check for 12 VDC there.
The red fat one?
I would identify #4 since that is easily done, and that will establish a reference for identifying the other sockets.
