SL/R230: Brake fluid change - not flush
Old May 11, 2020 | 08:55 PM
alexisvx's Avatar
2009 SL550
Hi all,
Having researched this a bit, doing a full break fluid flush is quite involved and I'm not ready to do this yet.
Is it beneficial if I only drain the reservoir (leaving a bit of fluid so as to not cause air bubbles) and then just top up with fresh fluid to the proper level? Is this considered useless or is it good enough? Perhaps I could do just that and in 6 months do the same when the fluid has had some chance to move around?
Also is there much difference between Dot 4 and Dot 4+? Should I use one over the other? I have an 2009 SL550.
Old May 12, 2020 | 01:34 AM
pmercury's Avatar
member
CL
Originally Posted by alexisvx
Hi all,
always suck out all fluid from the reservoir first then fill il to to the top then start beelding
just doing this without bleeding is a loss of time and has NO effect
it will not "move around"
you can use dot 4+ if you originally have dot4
Old May 12, 2020 | 07:07 AM
matk's Avatar
R230 350SL
Im going to assume from your post that you are actually due a brake fluid flush?
It isn’t going to help you. You will still have old fluid in all the lines. Old fluid absorbs moisture, which affects compressibility and will effect your braking power.
Long term and in the extreme that moisture can start corroding stuff too.
Don’t take the short cut, do a proper full flush. It’s not like it has to be done every day, once done it won’t need it again for a couple of years.
Old May 12, 2020 | 07:20 AM
onewhippedpuppy's Avatar
Plays With Cars
If you invest in a good pressure bleeding tool, like the Motive pressure bleeder, brake fluid changes become incredibly easy.
Old May 12, 2020 | 10:06 AM
kbob999's Avatar
'20 X5 M50i; '17 Ram 3500; Golf Cart; Bikes; Scooters
^^^ What he said. I have the Motive and use it all the time solo with great results.
Old May 12, 2020 | 02:02 PM
cjennjr's Avatar
2005 SL500
I heard the brake systems are ultra-sensitive on SL's and you will get errors while flushing the brake fluid. If this is not the case, I can DIY and save some money. Do you have to use the Motive bleeder system or can you use
any compatible bleeder system on my SL?
Old May 12, 2020 | 03:00 PM
kbob999's Avatar
Originally Posted by cjennjr
I heard the brake systems are ultra-sensitive on SL's and you will get errors while flushing the brake fluid. If this is not the case, I can DIY and save some money. Do you have to use the Motive bleeder system or can you use any compatible bleeder system on my SL?
To DIY - You will need any compatible pressure bleed system that has a cap to fit the Mercedes brake fluid reservoir, and at least a quart of DOT 4+ brake fluid.
The key is putting the car to sleep, and keeping it asleep, while working on the SBC system.
Attached are some informative files, and the method used for brake work WITHOUT SDS, which is perfect for DIY.
Follow it carefully or results will not be pretty, or worst case - harmful to your health. You have been warned.
Note that I have done this numerous times and it really is not a big deal.
Just don't wake up the car...simple. Put the car asleep and move the keys to your bedroom under your pillow. It will not wake up.
File Type: pdf
File Type: pdf
File Type: pdf
Old May 12, 2020 | 03:30 PM
alexisvx's Avatar
2009 SL550
Thank you all for your advice: I'll have to do a proper flush then.
I saw a few online videos (although I couldn't find any new ones for a post 2009 SL550) and I admit I am a bit daunted by it being new to DIY. I'll buy the proper tools and give it a go.
I have the Foxwell N530, so I'll need to find the function to disable the brakes if it's available.
thanks again.
Old May 12, 2020 | 05:37 PM
2007 SL600's Avatar
2007 Mercedes SL600
Many thanks for the informative information provided.
I have a 2007 SL600.
1. Raise the hood, car sets for several hours.
2. Car keys hidden under my pillow.
Safe now to hook up the Motive Brake Bleeder and bleed brakes?
No need to use SDS system?
Old May 12, 2020 | 05:46 PM
kbob999's Avatar
Yes. No SDS required.
The instructions in the docs say "roll down the window, then lock the car" to prevent someone opening the door and waking the car.
Having the window down allows access to the ignition (without opening the door) to turn the key on (when done) and do the left side wheel spinning that will reset the SBC.
Read the instructions and have a copy at the workspace when doing the work.
Afterwards...Go buy cases of wine with the money saved. Savor your new skills. Be more attractive to the opposite sex. Enjoy life and the pursuit of happiness. You have earned it.
Old May 12, 2020 | 06:44 PM
kbob999's Avatar
For my foreign friends who cannot translate the PDF docs:
The most important thing is to put the car to sleep first.
Open the engine hood.
Roll down the driver window
Lock the doors and the car with the remote key.
Put your keys inside the house under your pillow
Wait 10 minutes, and the car is asleep.
Do not open the doors or trunk! Keep the car sleeping.
Bleed the brakes with your pressure bleeder.
When done, you have to put the key in the ignition without opening the door.
Turn the key to position 2 but do not start the car.
Rotate both the left side wheels a couple revolutions and within 30 seconds of each other.
Turn the key off, then unlock and open the door.
Finito! You are done!
Old May 12, 2020 | 07:24 PM
Ivan750's Avatar
Mercedes SL r230
Old May 12, 2020 | 08:50 PM
alexisvx's Avatar
2009 SL550
I have a Foxwell diagnostic, what function do I need to look for and see if it can disable what I need?
Old May 13, 2020 | 05:37 AM
Ivan750's Avatar
Mercedes SL r230
With this tool can you change the brake fluid without problems? I want to ask before buying it
Old May 13, 2020 | 08:34 AM
Plays With Cars
I'm not familiar with that specific tool, but it looks just like the Motive bleeder that I have. Just make sure you get one that has the correct cap to fit a Mercedes, which also fits basically every other European car like BMW, Porsche, Audi, etc. US made cars have a different cap design, as do some Japanese.
Old May 13, 2020 | 11:32 AM
cjennjr's Avatar
2005 SL500
My intention is to jack up one wheel at a time and bleed instead of putting the whole car on jackstands. This might be a dumb question, but do I have to put the car in neutral in order to rotate the back wheel??
Old May 13, 2020 | 11:54 AM
kbob999's Avatar
Only if you have a locking differential (not likely).
Old May 13, 2020 | 01:02 PM
Plays With Cars
Also, not saying that it's the "correct" approach, but when I replaced brake pads on all four corners a few weeks ago I just unplugged the SBC module.
Old May 13, 2020 | 01:34 PM
cjennjr's Avatar
2005 SL500
Well, I guess I have one, because every year i remove my wheels to clean the brake dust that accumulates on the
inside of the rims, and both rear wheels are locked when I take the tires off the hub. Do I need to apply a little force or should they
roll freely? I don't want to do the job and get stuck because I can't "spin" the rear wheel. BTW, I have a 2005 SL500.
Old May 13, 2020 | 02:25 PM
kbob999's Avatar
Make sure your parking brake is not set...that would prevent them from spinning.
The SBC tends to clamp the brakes when awakened, which may contribute to your issue. See if you can keep the car asleep.
Then you might need a little force to overcome the friction in the drive and brake systems.
You could also jack the rear of the car from the differential (if you can reach it) and that should allow the wheels to spin.
Factory locking differentials were a rare expensive 030 performance option, and aftermarket diff would be costly for this car, so I don't think you have one.
To be honest, I think you could get the SBC brakes to work without spinning the left side wheels, but that is what the factory wants you to do.
Old May 13, 2020 | 03:17 PM
Plays With Cars
Is your car in park? The rear wheels will be locked unless you put it into neutral.
Old May 13, 2020 | 04:42 PM
Ivan750's Avatar
Mercedes SL r230
a new question, should we leave the car on the N? And another doubt, when you say the left wheel is the wheel on the driver's side in Spain? thanks for your advice
Old May 13, 2020 | 05:27 PM
cjennjr's Avatar
2005 SL500
Yes, the car is in park, which confuses me when others say the rear wheel should be free enough to "spin." That's why I asked the
question should the car be put in Neutral...
Old May 14, 2020 | 08:16 AM
Plays With Cars
Yes, the car should be in neutral to spin the rear wheels. In park the parking pawl engages and locks your transmission into place, hence why the wheels don't spin.
Old May 14, 2020 | 09:29 AM
poppyboy's Avatar
2005 SL55 AMG
I’m confused. I bled using the Motive pressure bleed system. However, without SDS, doesn’t a substantial amount of old fluid remain in the SBC module, even if “asleep”? Since the fluid was so filthy, I ended up bringing it to my Indy, who did a full flush using SDS.
