SL/R230: Question for the 2009 Owners
The spring in @DavidCA's post above is a small gas strut that supports the lid. Yours is probably due for replacement (unless of course the 2009 is different). Let me know if this information does not apply to your 2009.
Open the center console, and there should be screws in the back of the compartment near the courtesy light, take these out and then shut the center console lid. Now you should be ale to lift the rear section of the center console (the part to the rear of the console lid, lift from where you removed the screws and then slid it forward). Now you should see the gas strut. I attached some pdf instructions for removing a module under the rear center console, but these instructions might help you understand how this rear console cover comes off.
Here is a thread on replacing the gas strut: https://mbworld.org/forums/sl-class-...placement.html
I purchased my replacement strut part number 2309800064 (230-980-00-64) from www.liftsupportsdepot.comfor about $70 (expensive, but I didn't want to try and modify a generic strut).
One tip, once the cover behind the armrest is removed, the console lid can be opened up a little further. However, at first it didn't seem like it was opened far enough to relieve all the pressure on the strut. But I kept messing with the lid and eventually it opened even further (I can't remember if there was some release to get the lid to open far enough or maybe it just pulled open further), but eventually it did open far enough so I didn't have to compress the strut to remove/replace (went in easy after the lid was open far enough). Hope this makes sense. There are some other tips in the thread link above.
Hope this helps.
Lee
Lee
There are the two screws inside the console compartment that need to be removed to take out the rear console cover: http://www.bynarus.com/public/car/reararmrest1.jpg
Once the screws are removed, close the console lid, and then lift the "REAR CONSOLE COVER" (not the console storage lid) by lifting the cover in the front and slide it out towards the front of the car (the console lid and compartment remain in place) Here is a pic of the rear console cover completely removed:
http://www.bynarus.com/public/car/reararmrest2.jpg
http://www.bynarus.com/public/car/reararmrest3.jpg
Here is a picture of the console with the rear console cover removed (the closed console lid is the lower left corner of the picture, and you can see the exposed lift support strut in the middle of the picture): http://www.bynarus.com/public/car/reararmrest4.jpg
Here is a link to a whole bunch of info on removing interior stuff (and where I found the links above): https://www.benzworld.org/threads/ce...embly.1688422/
Hope this helps. If yours is different, you might post some pictures of the inside of your console storage compartment.
Lee
I actually test drove several other R230s that had the tray, so I'm 99.9% sure mine doesn't have it. I'll poke around later today and make sure I'm not a moron.
