SL/R230: Burning transmission smell
I have been reading some of the other threads on the forum regarding this but wanted to see if this is normal behavior on these cars. When I am driving pretty hard (redlining) I get this foul smell from the bottom car (I think its the bottom anyway). It doesn't smell like burnt oil but more like burnt transmission.
I have had the car for about 4 years but only put around 10,000KM on it and haven't changed the transmission fluid. The car has 72,000KM on it and its a 2003.
Is this smell normal when driving hard? I think that I will change my tranny fluid just to be safe. Is that recommended on these vehicles?
Thanks!
Thanks!
Thanks!
Driving a 17 yr old Benz with fairly low Km’s and romping on it brings sedentary issues to the surface. Like a burning smell caused by dirty aged ATF being glazed onto the clutches that have been rotating in old, badly degraded fluids.
Elephant in the trunk is; having left that soup stewing till present now you have to play by German car rulebook. Changing fluids only likely will almost guarantee a blockage caused by that sludge buildup finally freed and block the pump frying the clutches and valve body.
If you want to keep the car, have the valve body reworked (the plastic on the servos and the PC connections break with age) change the clutches and have fluids completely flushed. You’ll actually save yourself almost the same it costs to do the repairs rfn instead of have it fail/tow bills repeatedly and then paying to have it all done anyways
Good luck
