SL/R230: 2004 SL500 Rebuild
As for the frame alignement, I got the frame specs and meticulous measured all the points that I could. The damage looked far worse than it was. The ac condenser just had a little bow to it. The main reason for the complete front tear down was to replace the one high pressure ac hose that had a slice in it...AND to measure all the frame points. The front crash bar had a little ding and the crash horns weren't even damaged. Everything was within spec. Lucked out i suppose. I did end up replacing everything anyways even if it had a slight crack or distortion.
First thing I noticed was a vibration...so tried balancing the tires but every time I was getting a different reading on one front tire. Pulled off the tire and found the problem. Damn fix a flat in a can crap!
