SL/R230: DAS/STAR System
Old Jan 3, 2021 | 04:17 PM
Thrasher5621's Avatar
S65 AMG, SL55 AMG, SL500, SLK230, SLK350, GL320 CDI, CLK500
DAS/STAR System
Hello All,
Not really sure where to post this....
I want to purchase one of the DAS STAR systems off of eBay (China Knock-off)
I have read several post online and watched several YouTube Video's. As you might guess there are all kinds of opinions.... and "be careful" warnings.
Just looking for some insight from someone that has bought one of these.... and how well it works (or doesn't work).
Also was wondering if the ABC system can be reset with these systems and if you can put the car on "boogie" mode (for lack of a better term) to flush the fluid like they do at the dealer.
Any insight from someone who has purchesed one of these would be great. This is a eBay link to the one I am looking at.
https://www.ebay.com/itm/V2020-12-MB...y/124085483315
Mark
Old Jan 3, 2021 | 04:34 PM
BenzNinja's Avatar
Former Vendor
https://benzninja.com/special12/
+ that computer has a junk unknown brand hard drive with junk ram
it's just refurbished junk computer same as from ali but more expensive
this is chinese junk from ali sold on ebay
Old Jan 3, 2021 | 04:57 PM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
You got the best answer you could get in post #2 from Benz ninja. I went the China route (not knowing any better), and in spite of doing a ton of research I still ended up with garbage software and not the best hardware. Then I came across Benz ninja and had him convert my system to his software. Incredible install and support. There simply isn’t a better solution available.
Save your time and money and contact Benz ninja.
Old Jan 3, 2021 | 05:39 PM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
I have this one, had a spare laptop to dedicate to it. Like a lot of China purchases, documentation was not great, but seller was very good at working with me to get everything set up and working. It is a complete hard drive replacement, so I had to find a couple of drivers to put back on, but I would say that my IT skills are no better than moderate and I was able to get everything up and running. I have probably run 20+ quick tests and many other module scans and actuations on 4 R230's and a W221. So far, it has done everything I need it to do. You can buy cheaper on Ali, but Ebay with US shipping and 30 day return is worth quite a bit for this type of purchase. YMMV and others will have their own opinions, but it worked for me.
https://www.ebay.com/itm/MB-STAR-C5-...4AAOSwYAVebu0m
Old Jan 3, 2021 | 05:44 PM
BenzNinja's Avatar
Former Vendor
https://www.ebay.com/itm/MB-STAR-C5-MB-SD-Connect-Compact-5-Multiplexer-Diagnostic-WIFI-for-Mercedes-Benz/383465635669?hash=item5948553f55:g-4AAOSwYAVebu0m
that is a fake C5 clone
It's a C5 casing that has hybrid C4 clone crap inside
a lie in the tittle already, how can anyone trust someone who sells a SL350 as a SL65 ?
A real C5 has a hard drive with xp inside
the real C5 software was discontinued by MB on 2020.06
but glad you are happy with functions it has
in reviews:
computer has no SSD neither 8GB ram, all unknown brand chinese of course
vediamo 5.1.0 is not the latest
last vediamo was 2015 and 5.01.01
Old Jan 3, 2021 | 06:36 PM
kjb55's Avatar
Originally Posted by bobterry99
There's no need to spend $800 to obtain a Star Diagnosis System. I'm sending you a PM.
you get what you pay for. I went the cheap route and flushed that money down the drain.
Old Jan 3, 2021 | 06:49 PM
BenzNinja's Avatar
Former Vendor
happy you joined the real thing last year
Old Jan 3, 2021 | 11:38 PM
ml320x5's Avatar
R230 2005 SL500, 1952 MGTD, 1973 MGB, 1998 ML320, 2002 X5
Originally Posted by Thrasher5621
Hello All,
Mark
Since You asked, I will share my own experience. Bought mine through Aliexpress (Shop smart). I bought the turn key system (Don't want too much headache) about a year ago. Came with C4, Mux(cables), used Dell D630 with 4G ram, SSD hard drive, Not a VM system so its faster. None of the systems came with instructions so if you are not comfortable with computer, it may be a problem.
Cost me about less than $600. Reasonable shipping time (may be a month if I remember correctly). Somewhat helpful seller if I ask (but I figured it out in time). So far I used it to fix/troubleshoot SLK (R170), SL (R230, R129), Crossfire (same as SLK) convertible top, ABC Rodeo, Reset error codes, Lowered ride height, assign keyless go key slot, Brake Pads ...etc. So far so good. The store is OBD2Device Auto Diagnostic tools Factory. Just so you know. Do your own judgement. Good Luck!
Old Jan 4, 2021 | 02:13 AM
BenzNinja's Avatar
Former Vendor
Just that everybody knows and it to be clear
Specs to run late Xentry is minimum 8 GB ram and i5 processor
only this shows these people are not serious
they also have no idea of what software is
The incredible below low profile unnamed ram and ssd they put in those 30$ dell's, hacked windows, all this explains the low price (most don't even use ssd's )
do your own judgement, after all, if you want to save the price of 1 tire,
stop feeding China by getting their software junk.
we are forced to get the C4 hardware there, you want to donate even more ?
read read read , it's all over the forum and in my reviews and personal account history
You can not judge something you never used. My users had them before moving on
Das 2008 is in NO way the the best release for MY2009, this is just a 1000x repeated trolling lie. as you can't even update your modules nor go online in the first place.
Then it is for C3 only, read this: https://mbworld.org/forums/sl-class-...ltiplexor.html
Old Jan 4, 2021 | 10:13 AM
HLG600's Avatar
2009 SL63 AMG
Peter's system was a significant improvement over the diagnostic kit I bought from a reputable source in the UK. At the moment I am running a mix between the hardware from the UK and his install on a spare Lenovo laptop I have (with a few upgrades).
Specifically, the biggest differences:
-Much faster to load and run the diagnostic tools.
-WIS built in, allowing me to access key information without leaving my garage or running two machines.
These upgrades, coupled with the lifetime support, are worth it, IMHO.
I am very supportive of these services on here because I've been around the automotive scene long enough (and across enough different platforms) to recognize quality that stands out.
For anyone looking for a top shelf tool, this is it.
For anyone looking for something much more budget friendly, Foxwell makes some very nice diagnostic tools at a fraction of the cost.
The problem with the "AliExpress Specials" is that it is a complete coin toss. Best case scenario, you get a slow tool with limited support. Worst case, assuming it arrives, you get complete junk.
Old Jan 4, 2021 | 07:52 PM
NHSl550's Avatar
2007 SL65, 2009 SL550, 1991 SL500
Hello All,
Mark
I bought 2. 1 from China and 1 off of Ebay. Both sucked. Both garbage. Contacted Peter (Benz Ninja) and never looked back. Take your chances with junk or do it right the first time.
Old Jan 4, 2021 | 08:25 PM
Gene Fiorot's Avatar
SL500
It is overwhelming the feedback from Buyers of garbage who have joined the ranks of the BenzNinja Organization. Peter is the best, the equipment works, and the support is outstanding. Those naysayers repeat the same mantra about the cost with no viable alternative. Ignore them that is my Xentry Advice.
Old Jan 5, 2021 | 11:10 AM
ml320x5's Avatar
Here's another good reading material. Hope this helps. If you are not comfortable with Hardware/Software. Sometimes buying a support unit may be a better choice.
https://www.evilution.co.uk/info/buying_mb_star.htm
Old Jan 5, 2021 | 11:28 AM
BenzNinja's Avatar
Former Vendor
outdated info by sponsored chinese crap stores
C5 is a fake hybrid C4 not a clone at all, a Chinese scam
not newest at all as explained previously
other info explained here
also, as said previously
You must NOT run Xentry on anything else than i5+ processor, SSD HD and 8GB ram
This is a good example of how Chinese lies get into our ears
a website sponsored by 6 Chinese crapstores
ONLY BUY A C4 wherever you want but with ADG426B & AM79C874VI chips
I said this multiple times
The store doesn't mention the chips = they sell junk
or a C3 if you like struggling and old slow vintage stuff for windows XP, forget about recent software, online and more
or if you have 2000$ to spend, get a genuine C6, functions will be the same as a C4 with DOIP option quality clone
C6 clone is junk, for now
Old Jan 16, 2021 | 09:59 PM
*** UPDATE ***
To EVERYONE that is thinking about purchasing a DAS/Star system.
Don't mess around! Peter is the MAN! After 27 years in business I can tell everyone... Peter's support has been the BEST I have ever experienced. His systems WORKS!! I am sure how much clearer I can be on this.
His price is more than fair and he is easy to work with!!!
If you are into working one you Mercedes and giving it the care it deserves..... make this purchase. Follow Peter's advice on what you needs and you will be a happy human!!!
Can't say enough good things about Peter or recommend him with any higher regard!
Best To all.
Mark
Old Jan 16, 2021 | 10:12 PM
SL500
Damn Tootin in SPADES!
Old Jan 17, 2021 | 02:44 AM
BenzNinja's Avatar
Former Vendor
*** UPDATE ***
Best To all.
Mark
thanks !
Old Jan 17, 2021 | 04:04 PM
SL500
Old Jan 18, 2021 | 12:43 PM
kjb55's Avatar
I recently learned that BenzNinja recommends purchasing a multiplexer from the very same website as me and others have recommended for years; i.e., aliexpress.com. Hmmn...
This, and your other posts, are pointless. This community, and other forums, deserve to know from real customers what is out there to diagnose and service their cars. There is no point in bringing up Foxwell or any other 3rd party solution as a comparison to a DAS/Xentry system. Why would you pitch unknown origin hack software that's only good to 2009? Many updates come years after the actual model year and your system quotes are already at $350!
Time and time again - Peter's customers (me included) advise that their investment with Peter is second to none and it is the BEST solution that truly gives you professional level diagnosis for DIY prices. Furthermore - some of us (me included) went with very well researched systems from China - and in my case - got burned.
What you owe this forum and the others that you troll is ... What is the point of your post(s)? Do us all a favor and either substantiate what you're peddling (you haven't thus far) or leave these forums to what they're meant to be - a true resource for the DIY community that enjoys the capability to accurately diagnose the problem and fix it with the members support.
Old Jan 18, 2021 | 01:10 PM
SL500
I thought the Moderators took care of this last time.
Old Jan 19, 2021 | 11:53 AM
onewhippedpuppy's Avatar
Plays With Cars
Benz Ninja, as a potential customer I wanted to provide you with some feedback that you might find helpful. When I purchased my R230 to complement my W212, I reached out to you for pricing and more information on your services. I am an engineer and have faith that I could sort out a STAR system, but also don't want to spend hours dicking around with a computer. I will pay for quality, and was seriously considering your services until I did a little reading on this forum. You need to understand that as a service provider, you are selling yourself and your expertise. You don't deliver a product, you are selling you. So as a potential customer, when I found numerous threads of you conducting personal attacks on anyone who offers up an alternative to your service, it led me to reconsider. You are a paid sponsor, and you are operating a business, and I never begrudge someone who is trying to make money. BUT, you also have to consider that this is a FREE internet forum where people come to solicit FREE advice for the repair of their car. While it's fair to note that buying any Chinese hardware has risk (even those you recommend), it's not a good look to vigorously go after anyone who offers up a lower cost alternative to your services. There are many people who have purchased a complete STAR system from China that are perfectly happy with them, what you offer very well may be better but it's also more expensive. Going after anyone who offers an alternative only makes it look like your product isn't actually worth the money.
I still haven't purchased a STAR, and still might consider what you have to offer in the future. I don't know you and mean no offense, hopefully you can take this as constructive criticism.
Old Jan 19, 2021 | 01:07 PM
BenzNinja's Avatar
Former Vendor
Great comment
I have no problem with different people showing their point of view
I have ONE problem with ONE TROLL
Now,
1 I am same price or cheaper if you buy the Chinese stuff from ebay. but you have me included and warranty
2 ALL the software, all over the web from ANY of these stores are incomplete. the DO NOT have the functions I provide with my setup
3 I do not force anyone to buy my service, I even posted the solution to buy the exact hardware I provide sources for multiple time
4 If I would not be tailed by this INFAMOUS TROLL, I would not be posting sometimes excessive words. Just check history, you will see that each time the TROLL gets hiss *** kicked, he leaves for a while and ambiance is great again.
5 I help and helped out many many members by remote, on their ****ty bugging Chinese 100$ software, repairing the software a little before I was even able to use it as it should. I NEVER charged any.
The point is that ALL my users, ALL the workshops represent me and post all over the place what their experience was
and the result is, that many used several self installed, the Chinese and any other versions and source. They all, ALL say that my work is the best ever, far superior over all these
This said, anyone is free and my now over 200 members club is growing like hell. 1000% delighted customers and some now friends. And I am proud
PS:
Please understand my nerves, when i see that the TROLL isn't only satisfied with posting the same stuff here over and over, but he also posts disgusting insulting words on me on another forum every week. A forum where insults are apparently allowed. But happy that most people don't stop there and read more to find who I am.
the for the troll:
of course, that is the only place
but not in the store you bought your junk !
Old Jan 19, 2021 | 08:43 PM
HLG600's Avatar
2009 SL63 AMG
Oh FFS, enough of this garbage.
@bobterry99 You are not the only senior/experienced member in the picture and that post of yours about Peter exploiting people who are "lacking knowledge" is silly.
Frankly, you forfeit the right to play the objective individual who's just presenting all options when you refer to someone with perfect customer satisfaction as a charlatan, especially considering that you have zero direct experience with his solution.
That said, to address where you are coming from:
-STAR clones from China have been around forever, so anyone new to this who spends a few minutes researching will know that solution exists.
-I'm sure most, if not all, who purchased Peter's system knew about it too.
-Reiterating my earlier point: are there many unhappy customers? Are there any at the moment? His work speaks for itself if you consider the entire picture.
Old Jan 19, 2021 | 09:05 PM
SL500
Again I am surprised after so many vicious posts by this BobBerry Character why the Moderators of this board have not taken action about this poster. It surprises me since this is one of the most polite forums I have ever been associated with.
Old Jan 20, 2021 | 05:52 AM
BenzNinja's Avatar
Former Vendor
This tells it all , not 1 ever 100% five star satisfaction rate.
