SL/R230: ABC Failure - Fluids everywhere
We had a lovely spring day here in Sweden (after a cold & snowy winter) so I decided to take my SL out of winter storage. I managed to drive it about 15 minutes before I received an ABC error on the dash informing me to stop the car immediately. I wasn't going very fast, but I was in the middle of the city, so I managed to stop within 100 meters or so. It was lowered all the way down towards the ground. The dash said it was attempting to raise the vehicle but I could see that it wasn't moving, plus it was steaming from the engine. When I opened the hood I could see hydraulic fluids everywhere. I am soon about to head down with a hauler and pick it up, so I will get a chance to investigate further tomorrow where the leak seems to be coming from.
I may need to drive it for 10-15 meters in order to get it lined up for the hauler, is that a definite no-no? Or is the likelihood of my pump already damaged pretty huge?
My uncle is helping me troubleshoot tomorrow morning, so I'll get back to you guys.
(Definitely NOT the way I wanted to start my SL-season!!
Hope yours will be fine and with only a small bill to pay. Good luck!
I don't think we'll be fixing this ourselves, unless you can seriously convince me otherwise?! It seems like a fairly 'simple' item to replace (compared to others, that is), but with everything that comes with working on the ABC system, it seems wiser to leave it to a professional.
I would replace the hose or whatever is causing your leak; fill the ABC tank; run the car up and down or rodeo; and drive on.
You may need to slightly pressurize the ABC tank to prime the ABC pump and get past the 'suction valve'. Once it starts pumping, you are good to go.
A shop mechanic would do the same.
The hose in question looks easy to access, compared to some of the others in the system.
There's about 50 people here that have done this. Ask questions if you need to.
Jokes aside, I appreciate your reply!I don't have STAR or a parts diagram for that system, so I'm curious if anyone would happen to know the parts number for that particular hose?
MBNUT1, thank you! I'm quite fond of it myself. It's an original pearl-looking paint called Designo Mauritius Blue and seems to be fairly rare in the world.
230-320-88-53 look into this part number I’m on mobile, but hope this points you in right direction. Labor is expensive. Previous owner did it on my car labor was over $800 if I remember from service record
You were so very correct, it WAS that high pressure hose. But it had another part number for the 2011 model, which I believe was A2303204153.
It was quite expensive, around 400 EUR ($475 USD), but they only charged me for an hour of labor (even though they spent 2 hours on it).
Thank you for your help; now it's finally back on the road again!
