SL/R230: Occasional BUT BRIEF RED ABC LIGHT....WHAT ARE MY CONCERNS
Old May 1, 2021 | 01:52 PM
Specialed1's Avatar
2005 500sl r230
An occasional but brief RED ABC WARNING LIGHT....What are my concerns and troubleshooting the cause....I recently replaced a main hydraulic line blow out...any info on this?
Old May 1, 2021 | 10:08 PM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
Is it when you hit a bump? That would most likely be a bad accumulator.
Old May 7, 2021 | 06:57 AM
Tommyboy928's Avatar
89 SL500 Silver ,97 SL500 Carlsson 04 Mercedes SL55 AMG , 07 Mercedes SL55 AMG convertedBlack series
sjekk level your ABC tank , cold or hot on dispstick.
then you have probaly like all older SL dryed out seals and O rings in system , can adjust my clock for when this will happend to all.. You neeed start with the sayd level, then add rubber conditioner , probaly ligt will go away.
https://mbworld.org/forums/sl-class-...e-oil-use.html
