SL/R230: Two questions for Xentry experts
Old May 23, 2021 | 01:29 PM
m60kaf's Avatar
SL500-R230
If you look at the R230 instrument panel as a pair of 3 line displays, in the UK the left display top line 1 always says the speed in kph. Where in xentry is there a setting to change this to mph?? ive tried various setting even managed to enable a neat little feature that switches the actual speedo dial to kph then back to mph in menus. Im presuming its some subtle region or key setting, please answer if you know
Also there is a feature where every 15 screen washes in an ignition cycle the headlights wash... Yes there is and after onver 10 years of owning the car only just found it in wis and it does do what it says, so obvious question is there anywhere to drop this to 4 or 5.. Central Gateway? A SAM?
Also slightly curious as to what AMG speedstep is?
Old May 23, 2021 | 01:39 PM
sunman2's Avatar
2014 E250
If memory serves me correctly, it is in the IC itself. It’s been a while since I played with a 230 chassis but have done it before. It is not in any Sam module or ME module.
Old May 24, 2021 | 04:51 AM
matk's Avatar
R230 350SL
Hi I’ve had this done this on my car by my local specialist. It was a couple of years ago so I’m a bit hazy, but I think it involves going into the dash settings and changing the region to “Rest Of World”
It can’t be done through the in car menus. It’s a legal requirement for UK cars to be able to display Km/hr at all times. Hence it needs region change on the dash which can’t be done through the car menus
Old May 24, 2021 | 05:05 AM
BenzNinja's Avatar
Former Vendor
I can do that by remote, its not with xentry
Old May 25, 2021 | 07:37 AM
DavidCA's Avatar
SL500 2009
Looks like all the " Specialist" guys are not so expert after all.
Control units>>Information and comm>>ICM>>Diagnosis to plant specifications>>Control unit adaptions>>Control unit adaptions(Variant coding)>>Variantenkodierung>>
Then set "United Kingdom variant" to disable, then F3 twice.
You can change the display between speed and temp. on the steering wheel.
Old May 25, 2021 | 07:52 AM
m60kaf's Avatar
SL500-R230
Interesting, I did that a few days ago which got rid of km/h but its been replaced by nothing in a couple of screens and trip mileage in 3
Old May 30, 2021 | 03:40 PM
m60kaf's Avatar
SL500-R230
This is my instrument cluster settings if anyone can see whi turning off UK variant changed top left line from km/h to trip distance instead of mp/h
File Type: pdf
File Type: pdf
