SL/R230: Rocker Cover question !
Old Aug 2, 2021 | 12:36 PM
Tony Ryan's Avatar
SL55AMG
Is the top plate on both of the M113k rocker Covers just silicone sealant or is there a MB gasket, mines in bits to vapour blast them and it looks like just a silicone ??
Old Aug 2, 2021 | 02:07 PM
latemodel21's Avatar
2003 SL55 / 2002 SLK32
Yes, only silicone on breather covers. Do yourself a favor and replace the small (aluminum?) screws that hold the breather covers down (they are definitely "single use")
Chris
Old Aug 2, 2021 | 04:21 PM
Tony Ryan's Avatar
SL55AMG
Thanks Chris , will do - maybe,lol .
Old Aug 2, 2021 | 05:03 PM
I use a delicate touch and a top quality torque wrench whenever possible, and I have still stripped 2 (so I always buy them first) .
Cheers,
Chris
Old Aug 2, 2021 | 07:28 PM
ItalianJoe1's Avatar
2003 CL 600
They are aluminum due to the covers being magnesium, yes be VERY gentle with them on install, do not use any sort of power tool, if you have them fully cleaned and a fresh bead of silicone they will seal just fine, don't need to be super tight (they will break well before super tight anyway).
Old Aug 11, 2021 | 07:28 AM
Tony Ryan's Avatar
SL55AMG
The Alloy bolts cleaned up and went back in nicely enough , Cam and breather Covers Vapour Blasted, Coil packs and HT leads cleaned and Duck oiled , plugs checked cleaned and gapped , it actually runs slightly nicer now too !
Old Aug 11, 2021 | 07:03 PM
Ralphie's Avatar
2004 SL500
Where is your ABC reservoir? Did you convert to coil overs?
Old Aug 12, 2021 | 03:10 AM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
But... on a lawn?
Old Aug 12, 2021 | 04:13 AM
Tony Ryan's Avatar
SL55AMG
Yes, good spot !
