SL/R230: R230 SL500 2002 accumulators
Old Feb 5, 2022 | 08:45 AM
stayalive's Avatar
SL500 R230
I did research, but couldn't find info...
How many accumulators does car use? 2 or 4? I assume 2, because there are 2 valve blocks...
TIA
Old Feb 5, 2022 | 09:25 AM
stayalive's Avatar
SL500 R230
Found it...
2 accumulators and 1 small as a return accumulator
Old Feb 5, 2022 | 05:10 PM
Rpach10115's Avatar
2005 sl500
There are 2 large accumulators, 1 smaller return accumulator, and one pulsation damper.
There is 1 large accumulator mounted to the front valve block, 1 large accumulator mounted to a separate chassis with the rear valve block. This is also where the return accumulator is located. This is located in the forward rear drivers wheel well. You need to remove the inner wheel well to access this.
On this year, the pulsation damper is mounted in the rear of the front drivers wheel well behind the side vent. It’s easier to remove the inner wheel well and drivers side vent to get to this one.
So, the answer to your question is there are a total of 4 in the car.
