SL/R230: Looking for a wind deflector for my 2005 SL
Old Feb 7, 2022 | 10:55 PM
Sergey84's Avatar
W140, R230
Hi fellas,
I just realized I purchased my used 2005 SL R230 w/o a wind deflector. I'd like to get one.
I have a few questions regarding wind deflectors:
1) Please tell me if OEM is the best option or there are other decent deflectors on the market?
2) I see they sell cheap OEM deflectors with torn mesh. I wonder if it's hard to replace torn mesh on OEM deflector? I contacted one random place that sells mesh replacement but they told me their mesh fits their deflectors, not OEM ones.
3) Please suggest where to get a replacement mesh roll or large piece of mesh for OEM deflectors?
PS: If you have OEM deflector for sale in absolutely perfect condition please let me know.
Thank you.
Old Feb 9, 2022 | 01:20 AM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
Re. your second question I think replacing a torn mesh would be difficult. With the deflector up, the mesh has a sloping 3D shape. It's a beautiful design but its effectiveness is limited when you're tall.
Old Feb 9, 2022 | 02:09 AM
Tom Manning's Avatar
2005 SL 500 R230
I've got the Airax.
https://www.ebay.com.au/itm/13390764...SABEgKa0vD_BwE
It's very good quality but you will lose the visibility of the reversing lights in the rear view mirror (not that I care about that).
And it's extremely effective in stopping all turbulence.
Old Feb 9, 2022 | 08:23 AM
Sergey84's Avatar
W140, R230
Thank you! I see few slightly used OEM deflectors for sale online and all of them come with tiny holes. I'll keep digging to better understand the repairability of the mesh... Considering the OEM deflector wasn't cheap I guess there should be a way to fix it.
I'm just 6'2". I guess it's OK for SL because it's pretty roomy inside.
Old Feb 9, 2022 | 08:29 AM
Sergey84's Avatar
W140, R230
Originally Posted by Tom Manning
I've got the Airax.
Thank you! Please tell if those metal (or plastic?) parts that rest on the roll bar, do they leave any marks?
I guess it's metal. Please take a look at this pic:
https://i.ebayimg.com/images/g/V~QAA...2J/s-l1600.jpg
I'm asking because I got a leather roll bar which is not grainy as on the pic and it's more delicate...
Old Feb 9, 2022 | 10:34 AM
I did notice the same thing. And, interestingly, the roll bar on that photo shows the vague imprint of an OEM wind deflector. Here's a pic of my car (summer...) with the deflector visible: no brackets, a metal bezel from L to R. The two straps do leave a bit of a mark, though.
Old Feb 9, 2022 | 02:04 PM
Sergey84's Avatar
W140, R230
Thank you!!
Please tell if your OEM deflector leave those "vague imprints" like on the pic I posted earlier?
PS: I think it's worth placing something between the roll bar and the straps. I can't see what kind of leather you have there but MY SL65 has delicate leather everywhere. It's good when you are looking at it and bad when you accidentally scratch it or press something on it like deflector etc.
I need to check my roll bar and see if there are any signs of deflector previously installed there.
Old Feb 9, 2022 | 04:07 PM
Yes I think it does, but -in my case- it doesn't matter if it does, because I only take the thing off for maintenance on the deflector or the car. And really, no one should take offense of the slight marks an OEM part leaves behind when temporarily dismounted.
Old Feb 9, 2022 | 06:36 PM
cdk4219's Avatar
95 SL600
Never had mind off to look at that, if it does come off, it will go right back on.
Old Feb 9, 2022 | 06:42 PM
2005 SL 500 R230
I've never had mine off but the two brackets look like they've left a fair indentation on the roll bar.
But the comfort of having the thing remove all turbulence is worth it I reckon.
Old Feb 10, 2022 | 11:06 AM
Took the deflector off and made this photo for you. Not too bad at all. It's cold out here now, a milder temp and a few minutes would probably even things out a bit. And it's on again..
Old Feb 10, 2022 | 11:54 AM
Sergey84's Avatar
W140, R230
Thank you fellas!
Today I came to this idea - why need to buy a metal wind deflector when hypothetically I could install some kind of mesh on top or attach it behind the roll bar and make sure it sits tight there? In this case I will have to raise the roll bar every time I drive my car with top down (if I really want to reduce the turbulence).
Old Feb 10, 2022 | 11:55 AM
Sergey84's Avatar
W140, R230
I see a hole at 10 or 11 hours - is it because of the straps?
Old Feb 10, 2022 | 12:19 PM
Not a hole, that's just material 'outside' the roll bar, pushed back a little by the strap. Making up your own contraption is a bad idea for (I think) two reasons:
1- the car is capable of high speeds. I imagine you have no wind tunnel at home tot test your design thoroughly. If you loose it you're a danger for others.
2- your design will probably not be as effective as OEM. I learned in an 80's Audi that putting up an OEM deflector behind your head was not enough. A strong draft drops down and pushes forward between the seats. You therefore need a 'hat shelf' as well. The OEM does that graciously, not with two flat planes, but in one sloping netting.
Conclusion: do yourself a favour (the joy of low price will be forgotten while the bad taste of poor quality remains).
Old Feb 10, 2022 | 12:58 PM
Sergey84's Avatar
W140, R230
Yeah, I agree with you. If only I could find one in great shape. I still don't know how to fix the torn mesh on a used deflector...
Old Feb 11, 2022 | 09:17 PM
BobCT's Avatar
SL550 2012
I have a basically brand new Windschott for sale
$200 shipped to lower 48 states. Shipping from CT. Screenshot of what it looks like below.
Bob
rdunne14@comcast.net
Old Apr 3, 2022 | 11:57 PM
~tc~'s Avatar
SL65 AMG
Do the smaller “tabs” of the or the Windschott or Aperta wear more on the leather? Is the OEM with its full width “ledge” a better design (note the imprint in post 11 - if a large area is doing that, I have to think a smaller area would be worse)
Old Apr 4, 2022 | 02:07 AM
I don't think it is that much of an issue. People understandably leave the wind deflector on permanently.
Old Apr 4, 2022 | 02:25 PM
marko69's Avatar
'01 CLK 430 cab, '04 SL500 (230K miles)
I replaced the windscreen material with some material I tried from ebay, and .160 dia. spline for screen doors. It is close enough for me to the original material. It stops the wind and I can see through it pretty well.
Only issue is that it doesn't stretch as much as the original but not really an issue. It does take some time to do this. Hard part is getting the old spline out. It's barried in there pretty good. I've had it on for about a year now with no problems. The material is really inexpensive so this install was just a trial run to see if I could do it. There are a couple of flaws but it looked so good I left it alone.
https://www.ebay.com/itm/15381707727...oAAOSwszVeNLF7
********EDIT***********
Very sorry guys.. It's been a year and I ordered both of these on the same day. One was to thin and the wind whistled thru it.
It may be this one below. I don't remember which one was the good one, luckily they're both cheap.
https://www.ebay.com/itm/38260208091...0AAMXQLs5Rq5V9
1 year ago after install
Today (It's a little dusty)
Old Apr 5, 2022 | 06:55 PM
g0rsq's Avatar
SL500
Marko69
Really interested in how you did this. I too looking at purchasing wind deflector with damaged screen, and re-placing mesh, but it looks almost impossible to dismantle frame without causing damage.
Can you remember how you did this, and any tricks you used to fit it?
Peter
Old Apr 5, 2022 | 10:00 PM
marko69's Avatar
No need to dismantle the frame. The original "spline" is sewn into the material. You have to take out the old spline which is barried into a channel in the frame. In this video you can see how it's done.
He wastes a ton of time cleaning up the old spline and reuse's it. You don't need to do that. Just get some .160 spline (just a smidge bigger would be perfect) for screen replacement, like a pool screen, and a spline roller. You can buy the original material from Germany which isn't too expensive, but the shipping is absolutely retarded.
Old Jul 14, 2022 | 09:20 AM
aolexy's Avatar
2005 E500, 2004 SL600
Hi Bob,
Do you still have the wind deflector? I am also in CT and can pick up.
