SL/R230: Auxiliary battery replacement
Old 03-21-2022, 07:32 AM
4show's Avatar
2003 SL500
What’s a good rear battery replacement? Is there a top 5? Looking to purchase in the Orlando Fl area.
Old 03-21-2022, 10:06 AM
brucewane's Avatar
2005 SL600
Get an AGM battery from your preferred local AutoZone/O'Reilly's/NAPA/etc.
Almost all automotive batteries in the US, regardless of brand, are actually manufactured by Johnson Controls or Exide, so there's not really as much variety as you might think (I think Optima makes their own).
Unlike standard flooded cell, AGM batteries don't produce explosive/corrosive gas under normal conditions so this is the type of battery to get to use in an enclosed space. AGM batteries can still produce these gases if they are put into an overcharge condition, so even though this is a very rare malfunction it's still a good idea to connect a vent tube to an AGM battery. Your car has a hole/grommet in the trunk floor right by the battery just for this purpose.
I got an Everstart AGM from Walmart a couple of years ago, does the job just fine.
If you drive your car less than weekly, I'd recommend setting up your auxiliary battery with a connector for a trickle charger/battery maintainer so you can easily hook it up when parked. These cars have a lot of systems that stay semi-awake while they sit, so if they're not driven very regularly to keep the auxiliary battery topped up they will throw error codes caused by the low charge state.
gaazmon (03-22-2022)
Old 03-22-2022, 07:56 AM
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
My experience is not buying an aftermarket battery and stick the Mercedes Dealer battery its only a fraction more. I have tried three other supposed oem batteries batteries and even when new gave issues with "no convenience function'' due to lack of power and leaving the car for a few days. Since I replaced with the Mercedes Stock battery I can leave the car in the middle of winter for 5 weeks and it starts right up with no warning issues and has been strong for 3 years now. I use the car only once a week and no warning issues, I also do not need any trickle charging nonsense.
Old 03-22-2022, 08:01 AM
4show's Avatar
2003 SL500
Only thing, MB don’t have free install lol. I think I’ll take your advice battery cost isn’t much different.
Old 03-24-2022, 11:08 AM
HLG600's Avatar
R230 SL63 | W220 S55
I'm likely going to upgrade mine with an Odyssey H8 AGM. Second to none when it comes to stability, reserve capacity and warranty.
https://www.fcpeuro.com/products/aut...odyssey-49-950
Old 03-24-2022, 11:31 AM
4show's Avatar
2003 SL500
I have a 2003 SL500 I’m looking for the auxiliary batter in the rear boot. Size size 48, H6 AGM
Old 03-24-2022, 04:15 PM
HLG600's Avatar
Odyssey H6 AGM - https://www.fcpeuro.com/products/aut...odyssey-48-720
Old 03-24-2022, 04:47 PM
4show's Avatar
2003 SL500
Oh ok thanx. How much better is this battery then MB at $200?
Old 03-24-2022, 04:49 PM
4show's Avatar
2003 SL500
And does this battery have vent tube holes?
Old 03-24-2022, 08:09 PM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
Costco has an Interstate H6 AGM, 3-year replacement warranty for about $160, Walmart's Everstart is about $170 with a 4-year replacement warranty. Given how hard these cars are on batteries, that warranty sounds pretty good.
Old 03-25-2022, 09:19 AM
HLG600's Avatar
The MB battery is perfectly fine and the Odyssey is just a level above. To me, well worth the $60 difference for the warranty alone.
This is an AGM (Absorbent Glass Mat) battery rather than a conventional flooded battery, and there are some mixed opinions on whether an AGM battery needs to be vented.
Per Odyssey, their batteries do not need to be vented.
Source: https://www.odysseybattery.com/wp-co.../AM-ODY-OM.pdf
Old 03-25-2022, 09:31 AM
4show's Avatar
2003 SL500
What about MikeJ65 comment for Walmart battery with 4 yr warranty also at $100 cheaper??
Old 03-25-2022, 11:11 AM
HLG600's Avatar
https://www.walmart.com/ip/EverStart...0CCA/944775111
Too many negative reviews for me to consider it. Given the R230's complex electrical system, I wouldn't cut corners on the battery.
If you are unfamiliar with FCP Euro, they warranty any part you purchase for life (i.e. the life of your ownership of the vehicle).
Old 03-25-2022, 11:59 AM
4show's Avatar
2003 SL500
Yeah, I’ve purchased parts from them before. Was aware of their warranty policy. But didn’t think it was for batteries. Ok I think you’ve made a sale lol. Thanks brother ✊🏼
Old 03-25-2022, 07:02 PM
Sozo's Avatar
2007 SL550
Aside from the Odyssey, any thoughts about the Interstate AGM Battery in terms of capability and reliability with our SL's?
Old 03-29-2022, 12:54 AM
tziady's Avatar
2008 Mercedes-Benz SL 550
On my SL I have used ACDelco AGM 48 batteries, and they have always worked beautifully. Only issue that I ever had was going flat when left offline for a long period of time (read 6+ months); but that is mostly my fault for leaving them connected and not trickled.
Old 03-29-2022, 09:47 AM
A1EK's Avatar
yes there is vent holes
Old 03-29-2022, 12:50 PM
tziady's Avatar
Vent tube / hose?
Talking about vent holes and esp. "vent tubes"; anyone know what the model number is for the tube in a 2007 SL 550? Or the specs? My hose is hosed. LOL :P
T
Old 03-29-2022, 01:12 PM
4show's Avatar
2003 SL500
Ok lastly, what about the interstate battery? I’ve had them in my other MB as starter battery. This is for the rear “auxiliary” battery, it’s different right?
Old 03-29-2022, 01:25 PM
tziady's Avatar
Yeah, it is completely different in my car. First you have lots more room and this battery is responsible for absolutely everything else in the car outside of engine ignition. That is the roof, stereo, seat functions, suspension functions and basically every other device outside of igniting the engine.
Old 03-29-2022, 03:33 PM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
Read 'starter motor' for 'ignition' and you are spot on, about the starter battery.
tziady (03-29-2022)
Old 03-29-2022, 03:39 PM
tziady's Avatar
lol..these are rockets. You have to "ignite" the engines. LMAO :P
Thanks for the correction! :P
Old 03-29-2022, 03:48 PM
elMacko's Avatar
SL 500 2004, Ford F-150-2014
Guys, what can be different from battery manufacturers....?
Raw materials.!
All of them are using the same technology..!
Mercedes does not make batteries. They specify batteries as the rest of manufacturers and put their brand on it.....so a AGM 70 A/h, H^ 700/760 CCA should deliver the same performance regardless of brand. The difference will be in durability which is linked to quality of raw materials..!
I am happy with my Duracell and no problems whatsoever, but if you are like my wife who prefers to pay extra money for Tylenol, instead of the much cheaper Acetaminophen..be my guess....freedom of spending!
The following 2 users liked this post by elMacko:
Crabsl500 (09-10-2022), tziady (03-29-2022)
Old 03-29-2022, 03:53 PM
tziady's Avatar
I highly agree with you, mostly. Esp. when it comes to differences between brand and generic drugs. Not only is some of the quality of the materials different; there are in some very well documented cases issues with difference in speed of absorption, quality of coating, and other factors that even in many states the doctor can ask for no substitution. Of course, some of it is paying homage to the drug rep that is paying for your kid's school new uniforms for their soccer team; but there are some real differences outside of the cynical beliefs. Some even experienced by me who is involved in the medical field and a life long patient.
Old 05-09-2024, 05:37 AM
xerxes's Avatar
sl500 r230
FCP lifetime battery warranty???
Ummm, i just checked their lifetime warranty policy: "...just get the item back to us".
That means you must pay the postage, right? ...and for a heavy battery (49lbs!), that will not be a $0.76 postage stamp, you know.
Furthermore, the item has to be defective, and not just down a few volts (which seems to the cause of electric troubles, even though the battery checks out to be within the realm of a good battery).
Id like to hear from someone who actually has done battery exchanges with FCP to know if the cost of postage and FCPs definition of "dead battery" are showstoppers in their Lifetime Guarantee program.
Thanks.
Quick Reply: SL/R230: Auxiliary battery replacement
