SL/R230: Does charging the rear battery also charge the front ?
Old Apr 16, 2022 | 07:49 AM
Mitleider's Avatar
Sl600
Good morning and Happy Holidays. Can anyone confirm if changing the “Consumer” battery in the trunk,with a trickle charger also charges the front batter too? Thank you
Old Apr 16, 2022 | 12:38 PM
TheSaint's Avatar
350 SL, R230 - 300 SL, R129 - 1964 Corvette Sting Ray Sport Coupe - Porsche 911 Twin Turbo (sold)
If you charge the battery in the trunk i am pretty sure that you do not charge the battery in the engine compartment
So if you want to charge both batteries at the same time over a long period of time i guess you will need 2 trickle chargers
I use a trickle charger on the battery in the trunk (the car is not being used during the cold and snowy winters we have here in northern Europe)
I never had to charge the battery in the engine compartment
Old Apr 16, 2022 | 06:49 PM
g0rsq's Avatar
SL500
If everything is working correctly, charging the consumer battery will also charge the starter battery.
Old Apr 17, 2022 | 01:21 PM
Keith Noon's Avatar
SL500 R230
If charging the consumer battery also charges the front battery then why doesn't the constant current drain flatten both of them and why do so many keep a charger on both?
Old Apr 17, 2022 | 02:28 PM
cdk4219's Avatar
95 SL600
I do not believe this is correct, I have both batteries out of my car and tested continuity between front and rear positive leads. There is none when no batteries are connected. This could change when power is connected to them, but I believe except for emergency operation they are separated.
Old Apr 17, 2022 | 08:07 PM
g0rsq's Avatar
SL500
The front and rear batteries are isolated, so no direct connection between them as you have noted.
Both batteries are connected to the BCM.
Inside the BCM is a DC to DC converter (circuit that takes one DC voltage and converts it to another DC voltage, usually higher). This is effectively a battery charger powered by the consumer battery that charges the starter battery. This is the only way the starter battery gets charged (exception below).
The consumer battery is charged directly by the alternator, in a conventional way.
The only other thing that is connected to the starter battery is the starter motor, via the solenoid. This is why the starter battery does not normally discharge, unless cranking the engine as there is no parasitic drain on it.
The BCM controls the charge to the starter battery (it monitors the voltage on both batteries constantly), and will stop charging it if the consumer battery is too low.
Everything above assumes everything is working correctly.
Under certain conditions the two batteries are connected directly together (emergency mode) and they will for a short period act as a single larger battery (usually to start the engine if starter battery is a little low), in which case the starter battery will receive a direct charge from the alternator for a short time, but that is not normal operation.
File Type: pdf
Old Apr 17, 2022 | 10:57 PM
Gene Fiorot's Avatar
SL500
Is the BCM the device that burns down people's houses?
Old Apr 18, 2022 | 11:14 AM
g0rsq's Avatar
SL500
No, they are called Tesla's
Old Apr 18, 2022 | 12:13 PM
SL500
I was being serious
Old Apr 18, 2022 | 03:15 PM
cdk4219's Avatar
95 SL600
Yes.
Old Apr 18, 2022 | 06:50 PM
SL500
I just wanted to be sure . A friend of a friend had his house burn down due to that module. Thanks Gene
Old Apr 20, 2022 | 11:52 AM
TheSaint's Avatar
I was 99,99 percent sure that if you charged the battery in the trunk there was no way you could charge the battery in engine compartment at the same time.
I often use a trickle charger on the consumer battery in the trunk and never had to charge the battery in the engine compartment.. Now i know why i never had to charge the battery in the engine compartment
I will have to read the PDF file because i really have no idea on how this is working
Old Apr 20, 2022 | 12:44 PM
cdk4219's Avatar
95 SL600
Great engineering
Old Apr 21, 2022 | 09:07 AM
user 4637262's Avatar
I am a new owner of a 09 SL550 - how concerned should I be with fire danger? Is there a fix? Should I be disconnecting the rear battery if the car sits unused for periods of time? Thanks
Old Apr 21, 2022 | 12:23 PM
TheSaint's Avatar
DELETED
Old Apr 21, 2022 | 02:25 PM
SL500
I sleep well at night since I installed my home alarm system fire/smoke detector in the trunk of the car.
Old Apr 21, 2022 | 06:04 PM
elMacko's Avatar
SL 500 2004, Ford F-150-2014
You shouldn't find things to worry where there is no reason to worry about it..! Otherwise we may call you the Worries man! Just sit on it, find a good road and put the pedal to the metal! Don't worry that you may be hit by a meteor, or lightening......life is full of dangers and if you worry about all them, you won't be living a life!
Old Apr 21, 2022 | 07:11 PM
SL500
Tell that to the guy whose house burned down. I believe you are not informed about the issue. I will leave your pontification at that for me. However to disparage a person who lost his home and tell me to "tell that to the guy whose house burned down" .I think, trying to be kind, you spell your name incorrectly. El Wacko would be more appropriate. While you threaten, "We may call you Worries Man". We Sir? Check your "Like" numbers it tells a different story.
Old Apr 21, 2022 | 10:16 PM
cdk4219's Avatar
95 SL600
It’s definitely happened more than once. There was an episode on the TV show Junkyard Empire where an r230 was purchased with the same trunk fire.
Not sure what actually causes it, but I do know it doesn’t make me feel good about the cars I have. The other issues with the car are quite a nuisance, but this particular one, even if it is rare is taking it to another level.
Old Apr 21, 2022 | 10:27 PM
cdk4219's Avatar
95 SL600
What about something like this to stick in the right rear quarters panel.
Old Apr 22, 2022 | 09:10 AM
elMacko's Avatar
Guys, I wasn't aware of this frequent incidence! Then I better keep this ride out of the garage and away from the house..!
I am aware that many homes have a gas water heater in the garage, and a small fuel leak may spark a fire, but for the trunk battery to cause the fire it should need a heck of a short and sparks. If the battery does not breathe correctly may create an accumulation of Hydrogen gas in the trunk which will burst if it finds an spark!
My apologies for the victims.!
Old Apr 22, 2022 | 10:24 AM
brucewane's Avatar
2005 SL600
It's not a frequent/common event, but it is a pretty well known issue. All evidence points strongly to something going wrong inside the battery control module, some kind of internal short that evades fuse protection and so allows the circuit to fully melt until it ignites. It wouldn't be a bad idea to have a smoke detector in your garage, but then that's not a bad idea even if you're not parking an R230 in there.
As far as the consumer battery and hydrogen gas - this is exactly why it is advised to use an AGM battery in this location. AGM batteries do not produce hydrogen gas under normal conditions, so they are always recommended for enclosed locations. They can still produce hydrogen gas if something in the charging system goes wrong and they are subjected to overcharging, so it's still a good idea to have a vent tube. There's already a grommeted hole right next to the consumer battery which lines up with a hole in the rear splash shield just for this purpose, so it's simple and cheap to install this safeguard.
All you're accomplishing with your snarky, sarcastic comments is
1) Showing that you're uninformed about known issues with the R230 and
2) Showing what kind of character you have.
Old Apr 22, 2022 | 04:53 PM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
On one of the forums an (apparently) well informed electronics savvy made an educated guess, pinpointing a possible root of the potential BCM fire hazard. It made a lot of sense to me.
Old Apr 22, 2022 | 04:56 PM
Oh and let's always try to see the positive in comments folks make. I can't believe anyone is out to hurt or insult others.
Old Apr 22, 2022 | 08:11 PM
SL500
Getting familiar with the BCM? Found this interesting and wonder how guys feel with the premise "replace with new one as a preventative"
