SL/R230: roll bar stuck up position
Perhaps your bar is up after an incident induced trigger (is that English?). Your bar needs to be all the way up before it can be lowered. If that doesn't work you'll have to dismantle interior panels and release the mechanism mechanically. Careful, read other posts about this.
Presuming the hydraulics and controls are all working.
2) Since you replaced the cylinder, was there adequate fluid in the pump and does the cylinder move when you try to raise and lower the bar? During emergency operation, the cylinder detaches from the cylinder and the spring on the left side deploys the bar. To lower, the cylinder needs to first be raised and reengaged.
It is possible that your pawls are not releasing, but I'm not quite convinced. You can manually release them and lower the bar manually. That probably won't solve the problem, but it will help you diagnose.
The two pawls are on the same valve and the rod side of the roll bar cylinder is pressurized whenever the pump runs. It is also the only line that holds pressure when the pump stops. The piston side of the cylinder should normally be open to drain, so you should be able to push it down when lowering the bar manually. It is possible that the valve is stuck 'on' and continuously pressurizing the piston side, forcing the bar up. You could remove line line 60 at the pump to test this. If that allows the roll bar to now be manually lowered, it would point to a valve problem (don't run the pump when you are trying this).
WIS often is like an over concerned mom with its warnings, but this one does sound plausible.
If you raise the roll bar with up button, both pawl cylinders should push in against the springs and relased the mechanical latching part (big black teeth rail). if one of the spring is not release, Roll bar just won't move at all. I suspect driver side pawl leakage(internal/external).
Keep this in mind if one wants to open the top and roll bar is in up position, system will lower the roll bar first, complete the top stow cycle and then raise the roll bar.
Also when you replaced the entire unit on the passenger side, those lower bolts may change the roll bar alignments.
When you lower the roll bar manually, did you and your son use screw driver up against the spring method?
When you hear the pump running, doesn't mean it is building up enough output pressure. Without pressure, nothing will work. Pawl locks/springs movement is the first good sign.
I would try holding the roll bar up button for few seconds at a time, do it few times. You don't want to overheat the pump. Meanwhile check for pump fluid level, other leakage. if there's leak, it won't build up enough pressure.
Another test is, remove line 60 from the valve block. While you push and holding the up button, fluid should come out. Make sure you put some towel around it.
Don't know what that means but there's a sticky about fixing a leaking soft close. Until you get at it, try not to slam the trunk lid too vigorously as that may crack your 3rd brake light, causing a potential leak and you want to keep the trunk bone dry. Enough hydrophobic stuff in there.
