SL/R230: battery
Old Jun 9, 2022 | 10:15 AM
njbiker2008's Avatar
sl 500 r230
Talking battery
To change out the consumer battery on a 2006 sl500 does it have a system to do this so the car does not go crazy?
Old Jun 9, 2022 | 01:11 PM
MBCO's Avatar
2015 SL550 & 2012 S550 4matic
If by “system” you mean an external battery charger, the answer is No.
There is a proper procedure to replace the consumer battery which includes the steering wheel rotation side to side and windows reset.
search is your friend.
Old Jun 16, 2022 | 02:47 PM
matthewlambert's Avatar
SL350 R230
I recently changed the consumer battery in a 350 r230, no reset procedure required. Just a simple swap out. Disconnecting the negative terminal first
Old Jun 17, 2022 | 09:02 AM
NHSl550's Avatar
2007 SL65, 2009 SL550, 1991 SL500
Remove the negative cable first. Then continue to change the battery. Some times you will get a light on the dash. Just open and close the windows once or twice and turn the wheels right and left and that will take care of it.
