SL/R230: Mixing R134a and R12
Old Sep 1, 2022 | 04:18 AM
Anders Lindgren's Avatar
r230 2003
Hi
When you filling up the AC. Can you mix R12 with R134a or dou you need to drain the R134a ?
Old Sep 1, 2022 | 07:54 AM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
Why would you want to put R12 in a R134a system?
Old Sep 1, 2022 | 08:20 AM
benz lurker's Avatar
2018 x2 2012 zr1
They can’t be mixed
Old Sep 2, 2022 | 02:11 AM
r230 2003
Instead of daining the exsting
Old Sep 2, 2022 | 05:09 AM
ygmn's Avatar
2015 E400 Sedan
NOOOOOOOOOOOOOooo
You do not drain an AC system.
You recover refrigerant and vacuum pump the system down to very low vacuum and then let it sit to check for leaks.
Then you can refill using proper gage manifold and refrigerant to amount manufacturer states.
Old Sep 2, 2022 | 09:52 PM
cdk4219's Avatar
95 SL600
Either you have deep pockets to purchase r12 and install it in a system designed for 134, or you have a car that was designed for r12, and have limited funds, but want to get cool air, and simply posted in the wrong forum?
Old Sep 4, 2022 | 01:14 PM
Gene Fiorot's Avatar
SL500
If that were the case you can convert an R12 system to use 134 without too much problem.
