SL/R230: Bose amplifier draining the aux battery?
Carefully pass test leads out of trunk across seal, and close trunk and lock car as normal, then wait.
800mA is a lot and will flatten a good battery in a few days.
To fully enter sleep mode, when measuring parasitic drain, you need to lock the car. You cant do that with the trunk open.
However you may get the results you are looking for, as all you are waiting for is the Amplifier to go into sleep mode, which it should do shortly after the head unit is turned off.
Measuring parasitic drain at the battery terminal is not very helpful, as you can not be sure what is causing it.
Better to do it at the fuses, using a amp-meter that connects directly to the fuse terminals.
