SL/R230: Water entering boot :(
Old Dec 29, 2022 | 05:52 AM
Decoy1982's Avatar
R230 SL500
Hi all
After some advice , I have water entering the boot Drain holes are clear and working as they should.
The water is entering the back of the boot, any ideas ?
Old Dec 29, 2022 | 04:44 PM
Dr. Plastic's Avatar
2005 SL500 & 2021 Jeep Willys Gladiator
Maybe the trunk was not closed all the way? Soft close failed to pull the lid down tight?
Old Dec 29, 2022 | 08:49 PM
Tom Manning's Avatar
2005 SL 500 R230
Check the seal under the rear window. Probably the water was running over the closed load cover then down the rear of the boot.
The factory rear seal under the windo is rubbish; it needs to be removed, cleaned up and sealed with new silicone. Any RTV will do but I used black.
This guide is the go.
Old Dec 30, 2022 | 03:48 AM
Decoy1982's Avatar
R230 SL500
Thanks guys will reseal the window and see if it stops
Old Dec 30, 2022 | 05:53 AM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
I guess you should be able to see if water travelled across the luggage divider. The dreaded leaking from under the window is probably visible first on the trunk liner around the wheel arches.
What never happened on mine, so can't tell the potential severity of it, is that the third brake light can develop a leak as well. Maybe probe a finger behind the trunk lid liner, for moist in there.
Old Dec 30, 2022 | 05:24 PM
2005 SL 500 R230
If that is your issue it should be pretty obvious, if you shine a bright torch in there, under the window, where the sealing strip bolts on with a nut each side. If it's been leaking there will be signs of rust and drips of water around the seal. While you're in there check for water ingress, pooling around the roof pump at the bottom of the boot.
Old Jan 3, 2023 | 05:04 AM
Decoy1982's Avatar
R230 SL500
I found the issue, it was a torn rubber seal, can anyone confirm this part as being A2307903098
Old Jan 3, 2023 | 05:08 AM
Decoy1982's Avatar
R230 SL500
Or is it thr left side 🤔
Old Jan 3, 2023 | 07:03 PM
You can repair that with a little swipe of RTV sealant/adhesive.
Old Jan 3, 2023 | 07:07 PM
2005 SL 500 R230
I'll take a bit of a guess that you might also have a leaking rear window seal. Have you shone a bright light up there or run your hand over it and checked for leaks? It's such a common failure point on the 230.
Old Jan 4, 2023 | 03:44 AM
Decoy1982's Avatar
R230 SL500
Good idea, will save me £150
Old Jan 4, 2023 | 03:47 AM
Decoy1982's Avatar
R230 SL500
I checked for leaks , only place where u had any water drops was from the 4x bolts. I have resealed these and hoping for the best.
However it will no doubt decide to test me again lmao .
Light idea is a good one, will try that today.
​​ideas thank you for tip
Old Jan 4, 2023 | 05:33 AM
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
The seal in the photo was were I had my issue, I removed the rubber temporarily, cleaned off the rust on the metal lip, painted then applied sealant and re-fitted the rubber seal, all dry now.
