SL/R230: Anything i need to be aware of with the SBC brakes? Change brake fluid 03 SL R230.
I am first going to drain out all of the old brake fluid before putting in new brake fluid and then bleed the brake system
Is there anything i need to be aware of thinking of the SBC brakes on the car?
You can pressurise the system with a power bleeder (no more than 10 - 15 psi) and push the fluid through the system to the bleeders on each wheel in turn until the fluid runs clear or changes colour, but this will not replace all the fluid.
Star cycles the SBC unit and empties it of all the old fluid. Without STAR you will not replace the old fluid in the SBC.
But we're not talking about a lot of fluid here so it's probably OK to do it the simple way with a power bleeder, which you definitely need as a minimum; something like the Motive or similar. If doing this way, don't turn the car on or press the pedal during the procedure.
I am sure i have enough brake fluid to flush to drain the system first and then bleed thru everything so the whole system will contain the new brake fluid.
Below is a picture of the brake fluid i got from Mercedes (with a discount)
Original Mercedes brake fluid part nr A 000 989 56 05 11, DOT 4 Plus for Mercedes SL R230 class
It says DOT 4 Plus brake fluid in the owners manual
The Owners Manual says DOT 4 Plus brake fluid
But i am not going to change the brake pads since it is no need for it
Using a power suction/bleeder that hooks up to an air compressor should do the job i guess?
I was thinking of first of all to drain out all of the old brake fluid and hook up the brake bleeder to the air compressor and suck in all new brake fluid.
The car takes 1,05 liter brake fluid and i have 2 liters so that should be no problem
It should be okay to do it like this or?
With STAR and when you replace the brake fluid what does the Star system do?
Cycle the SBC pump to clear it of fluid.
Get the Motive or similar. Forget the compressor. You only need a few psi to push the fluid through.
No.
If not using STAR, then:
Suction out the fluid from the reservoir with a clean syringe
Refill with new fluid
Attach the Motive and pump up to 15 psi
Open the bleeder from the rear left and watch until the fluid changes colour or runs clear
Repeat for rear right, front left then front right
At no time allow the reservoir to run dry!
No.
Thanks for letting me know
I had a feeling that there was something about the SBC brakes so i am glad i asked
Having said that i will do the brake fluid change like you have explained
I will be careful not to let the reservoir un dry.
I will start with the right rear wheel (that is furthest away from the brake reservoir) then the left rear, so the front right and finally the left front
I have one brake bleeder pump that looks just like this Motive pump on the picture below where you can pump pressure and i also have a brake bleeder pump that you can hook up the air compressor.
Brake bleeder pump
I agree
I am sure that 10 psi is more than enough to change the brake fluid
It took me 30 mins to change my pads and 3 days to clear the fault on the dash at a garage because I did not disconnect the SBC, the ended up having to up date software on my car to clear the error.
