SL/R230: Parked again BCM?
The left terminal (rear battery) read the same as the battery, the right terminal reads 24v. I figure it's a bad bcm. Youcanic is not picking up any codes from bcm. Fuses and relays all good. Any thoughts? I appreciate any input in advance.
isn't the bcm responsible for energizing the relay to switch front to rear? How do you suggest I check the alternator? It seems to be working.
thank you for the quick response
I got everything cleaned up, and tight.
Got it started, and monitored the charging for a while. Seems to working good now. I checked this morning, both voltages were good.
