Rollbar and convertible top not moving
Old Aug 21, 2023 | 10:38 PM
edj678's Avatar
06 Sl500
Just installed the left back trunk pump no more leaking. But top went up once then back down an that was it. I checked all the fuses, battery charge is good. The trunk load is working so the pump is fine. No more movement on rollbar or top. Any suggestions 🤔
Old Aug 22, 2023 | 07:57 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to R230 forum...
Old Aug 22, 2023 | 08:24 PM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
So roof and roll bar are both down, pump does not run when you try to move the roof or bar in either direction? Load assist works fine, pump shuts off after it raises? Fluid level is good?
Old Aug 22, 2023 | 10:21 PM
edj678's Avatar
06 Sl500
  • Correct everything thing else is good!
  • Fluid is still in the correct spot on the pump
