SL/R230: BCM alternatives
Old Jun 29, 2024 | 11:08 AM
elMacko's Avatar
SL 500 2004, Ford F-150-2014
Thank you gOrsq, I have been studying the schematic since yesterday and I can see K75 is a double through relay, where the positive signal for the coil comes from 30a and to activate a ground contact should come from pin 10 of the BCM to pin 1 on the K75. Will test all that today to see the results!
Old Jun 29, 2024 | 11:11 AM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
K75 does not control the consumers, just the front cigar lighter and the rear power outlet in the trunk. I'm really not sure what MB was trying to do with the dual pole relay. One pole is fed by F11, the other by F61. However, only one output is used. On the early cars, the F61 feed is used to power both the lighter and the outlet. On later cars, the F11 feed powers both. At the very end of production, they went to a single pole relay with power provided by F11. In any case, it is a normally closed relay, so without the BCM, you will still have power to both.
Consumer functions are controlled by CAN B. Non-critical functions require periodic messages from the BCM to function. Without the BCM CAN messages, these consumers will not function. In order for them to work, you ideally would have a system that monitors voltages and sends the appropriate messages. If you want to ignore voltages and just turn on all consumers, you just need a device to inject continuous CAN messages onto the CAN B network. On the Facebook BNS fire group page, there are instructions on how to modify a CAN filter to do this job.
Old Jun 29, 2024 | 06:26 PM
g0rsq's Avatar
SL500
Sorry I stand corrected. I misread the drawing. I had been reading the drawings for the W211 and got it into my head that the consumers were switched in a similar way.
Old Jun 29, 2024 | 10:14 PM
elMacko's Avatar
Mike, You are right, K75 does not control consumers. This morning I tested the unit by interrupting and grounding one of the coil poles (Pole 1) and the radio didn't come on, not the roof. By discarding possible feeds, this only leaves the CAN B connections 6 and 7. I need to find how to implement that CAN Filter..! I will look at the Facebook BNS fire group page..! I have measured the voltage on these terminals and are 12 VDC, but wonder if it is a modulated pulse!
gOrsq, before I saw Mike's message, I was going to let you know about my test...indicating the K75 is out of the equation..! Perhaps need to take a good look at the W211 system to see how the consumers are connected in that model!
I am sure that with the help of you guys at one point in time all this "electronic puzzle" will be decoded. This research will bring hopes to all other owners who at one point in time will face the same BCM dilemma.>! I will keep on digging and testing as time permits...my mission is completely bypass the BCM..! I already have the DC to DC charger charging the starter battery when the car is running..!
Do you guys have knowledge of this device below?
Thank you guys again...!
Old Jul 1, 2024 | 09:20 AM
elMacko's Avatar
Gentlemen, CAN messages are more complicated that I really imagined....After educating myself on CAN bus technology, I have learned that CAN messages are very similar to a software instruction similar to those used in the Config files of a computer. The Message has an identifier, which establish the address, a data field which is the main message, and the CRC field which acts as a spell checker to validate the message. So, to really customize a CAN message it is necessary to have the right tools which extract the data and then is analyzed in a PC. One of these devices is a Autopi Mini which plugs into the OBD2 and extracts the data. This is something for a Computer guru! Any around?
The USB-CAN-B in my message above is another tool which in a way would need the OBD2 adapter..!
Below is a sample of CAN messages.!
Old Jul 1, 2024 | 12:56 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Read S-Prihadi's posts.
Old Jul 2, 2024 | 02:03 PM
  #32
elMacko's Avatar
Bird man, searched for name and no results? Can you offer more details?
Thanks!
Old Jul 10, 2024 | 09:08 AM
  #33
Imageben's Avatar
W208
Have you been happy with the repairs from this vender? Did you purchase the fuse fix from them? Thanks
Old Jul 10, 2024 | 10:28 AM
  #34
Imageben's Avatar
W208
Tom in your BCM fix you add a 30 fuse. Is that better than a 25 fuse like on the fuse kit that “Mercedes top seals” adds. I’m just trying to understand. Thanks
Old Jul 10, 2024 | 01:10 PM
  #35
Bismarck's Avatar
2000 R170 SLK 320 manual, 2018 E200 E Class Estate, 2016 GLA 250, 1996 R129 320, 2003 R230 500.
If you mean me, I didn't have a BCM repaired there but the EIS, but having found someone who can fix these things when everyone else says they can't I thought I would pass on the word!
TTFN
Old Jul 12, 2024 | 12:39 PM
  #36
elMacko's Avatar
Das Geld, there is an affordable solution for replacing the BCM now...see my recent post on BCM substitution! You may be interested!
Old Feb 13, 2025 | 12:00 PM
  #37
scott7's Avatar
Originally Posted by Das Geld 2
eLmacko,
On the contrary you can be just like me. My BCM has been dead for over 4 year now. I have no interest in checking the prefuses or K57(whatever it's called). All I do know is DAS does not communicate with the module. My front battery does not charge.
I drive a few times a month. That means I hook up my CTEK once a month to my front battery, let it charge up and not have a care in the world.
Hey @Das Geld 2 , are you still driving the car with the BCM disconnected? I'm thinking about removing mine and charging the battery in the garage as I don't drive the car very often. What is your experience so far?
Old Feb 13, 2025 | 12:53 PM
  #38
Das Geld 2's Avatar
SL55, S500
Hi Scott,
My BCM is connected. Since I drive the car only a few times a month, I make sure to charge my front up with the CTEK.
I haven't driven her since November now. I'm considering looking into that aftermarket solution on Facebook for next season.
Old Feb 13, 2025 | 01:46 PM
  #39
scott7's Avatar
Ok, your BCM is still physically connected but it doesn't serve any particular role since the diagnostics is down and it does not charge the front battery. What engine do you have? Do you observe any battery usage while driving around and charging only at home, i.e. does it take longer for the engine to start when you drive back home from your destination?
Old Feb 13, 2025 | 02:26 PM
  #40
HLG600's Avatar
2009 SL63 AMG
D, I'd recommend reaching out to him now since there's been a lot of demand and a wait list.
Be sure to let him know your BCM is compromised, as he's (rightfully) prioritizing orders for cars with active issues.
Old Feb 13, 2025 | 03:06 PM
  #41
Das Geld 2's Avatar
SL55, S500
Correct, 55K, I'd say the first 20 restarts are fine. I pre-emptively change my battery every 5-7 years and replaced my front one when it had no issues. The starts have not changed, it just instant power. But if my front is not charging eventually the battery will be dead and won't start is my conclusion.
Thanks H, I'll get to it once I create a Facebook account This is low on my priority list right now. I feel like I'll only have 3-5 drives this whole year ^^
Old Feb 17, 2025 | 02:57 PM
  #42
HLG600's Avatar
2009 SL63 AMG
Make sure to reserve one of those drives for the trip to Phoenicia diner and all those mountain roads around it.
Old Feb 18, 2025 | 03:00 PM
  #43
Das Geld 2's Avatar
SL55, S500
Yes, I'll oblige as long as a 63 and 65 are on my tail
Old Feb 18, 2025 | 04:44 PM
  #44
HLG600's Avatar
2009 SL63 AMG
Haha, no promises.
Speaking of the 65, we were chatting about getting together once it warms up and conditioning all the trunk / roof seals again.
Might also be a good opportunity to get those BCM fuses installed on both of your cars.
Old Feb 19, 2025 | 11:04 AM
  #45
Das Geld 2's Avatar
SL55, S500
Talking
Haha, no promises.
Sounds like a plan!
