SL/R230: Can a 2003 SL500 be made reliable?
ABC struts can last like 130k miles, or they can blow out at 80k. It's just another part, just like a normal strut.
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Now I wonder what will be next!
Top works great. ABC functional, but needs some attention and will eventually go coilovers I'm sure.
Other than that and some minor cosmetic issues I'm working on, it's great. But it's not my daily driver either.
The replacement is done as Illustrated in a thread named THE BCM SUBSTITUTION IS A REALITY, in which is described how a stand along DC to DC battery charger is adapted with a programmable micro processor to take care of the BCM messages to the CAN bus.
The replacement is done as Illustrated in a thread named TlHE BCM SUBSTITUTION IS A REALITY, in which is described how a stand along DC to DC battery charger is adapted with a programmable micro processor to take care of the BCM messages to the CAN bus.
I’ve seen the following:
do not jump start the car
monitor the convenience battery for age and voltage
use an approved trickle charger on both batteries beyond 5days of storage
use a quick disconnect on the rear battery when car is stored
ive seen fuse bypass installed - not sure if this was home made or a kit from ..?
recently seen a complete bypass advertised and now sold on ebay.
https://www.ebay.com/itm/14589425675...is&media=EMAIL
assuming these are correct statements am I miss informed?
From my viewpoint, most of these incidents seem to happen in the spring time, when the cars come out of hibernation, and the likelihood of weak or dead batteries is common. There are no proven remedies to this issue, although the newest remedy seems promising, but with that remedy, the starter battery is charged equally with the consumer battery. Both are different amp hours, different charging needs and requirements as well as different composition ( lead acid vs AGM) which may raise different problems.
Take it as you will, but I don’t take car fires lightly. Any car that has a record of spontaneous combustion due to electrical issues is a problem. My simple hypothesis is that weak or problematic batteries are a large factor in these fires, but again my opinion isn’t proven, and all of the other remedies are just the same, unproven hypothesis
As for Jump starting, doing this to any Mercedes of this era or newer would be asking for all sorts of trouble, and doing this with a power supply that provides more than 14.5v would be receiving that asked trouble. These cars don’t like any of that, and more than likely if a jump start is needed, there is a battery that is usually in question. The r230 has many parasitic electrical drains, and that adds to the issues.
https://www.ebay.com/itm/145894256754
