SL/R230: 3d printer files
Old Sep 13, 2024 | 09:12 AM
Beeza's Avatar
R230 SL500
3d printer files
As well as this current R230 restoration project I am currently involved with, I have decided to get into a new hobby, 3D printing. I've ordered my first 3d printer, a bambulabs A1. It's something that's always interested me, so I took the plunge and I'm currently waiting for it to arrive.
One of the reasons I thought this would be a good hobby to supplement car restoration, is to be able to print hard to find or expensive plastic parts. For example, the little flaps that fill the gap of the roof strut when the roof is down. They seem to break frequently and Mercedes solution is to replace the whole trim panel at huge expense. Also the sun visor mirror flaps. The plastic hinge breaks and even second hand sun visors cost a fortune on eBay.
Are there any members here into 3d printing? Are there any files of parts around?
Old Feb 22, 2025 | 07:55 PM
normdy's Avatar
2003 SL500
mercedes r230 jack hole cover 3d print file
Looking for a mercedes r230 jack hole cover driver's side front in case you may have a 3d print file for that part....
Old Aug 11, 2025 | 10:41 AM
mfa0007's Avatar
SL500
I have a printer and was doing similar. The issue is the 3d scanners don't work so well ... Does anyone know where one could find the mech drawings for the parts? That could be converted to STL.
Old Aug 11, 2025 | 12:17 PM
streborx's Avatar
Top Answer: 1
G550
I've played around with 3D printing using a Qidi Max-Plus printer (about $1000 when I bought it). I use a design tool OpenSCAD, which is script-based. Instead of designing objects in 3D as with AutoCAD, shapes are defined geometrically, and merged or subtracted to create more complex objects, and then it generates STL files. Easy to use unless you're already AutoCAD proficient.
Much of what you can do with a 3D printer involves optimizing the printer's operational settings -- temperature, speed, density, etc., and it can take many hours of experimentation to find what works best for a particular part.
I designed and printed the MB star and attached it to an aftermarket wheel cover shown here. Unfortunately, I can't share the STL files because the MB logo is trademarked.
Thingaverse.com is a repository of millions of ready-to-print 3D designs.
Old Aug 14, 2025 | 12:03 AM
yovenim's Avatar
just looking
One of the reasons I thought this would be a good hobby to supplement car restoration, is to be able to print hard to find or expensive plastic parts. For example, the little flaps that fill the gap of the roof strut when the roof is down. They seem to break frequently and Mercedes solution is to replace the whole trim panel at huge expense. Also the sun visor mirror flaps StreamVouch. The plastic hinge breaks and even second hand sun visors cost a fortune on eBay.
Yes, a lot of members use 3D printing for this. Check sites like Thingiverse, Printables, and Cults3D for existing files, and if you can’t find your part, you can model it yourself or have someone do it. For car parts, PETG or ABS is better than PLA because they handle heat and stress better.
