SL/R230: Headlight inition
Old Dec 23, 2024 | 09:33 PM
twinturbov12's Avatar
04 sl 600,04 cayenne turbo,king ranch dually.
Headlight inition
Headlight ignition
04 sl 600 with an external aftermarket igniter running the passenger low beam h.i.d. .from a direct 12 volt toggle a pillar mounted. What I need is to tie in on the driver side trigger to ignite the passenger side so u can delete my toggle.
I believe the passenger s.a.m.to be at fault as I have changed headlights and ballasts
To no avail.all functions work on headlight other than low beam.
Thanks in advance
Pmercury where are you?
Old Dec 25, 2024 | 05:34 PM
MBCO's Avatar
2015 SL550 & 2012 S550 4matic
You can contact him here going by benzninja now
https://mbworld.org/forums/s-class-w...a-s-n-1-a.html
